Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Where can i find the converge board?
Where's the converge board locate?
  • 927 Answers
Good day, georgehoops;
If you can't find the convergence PCB. I would recommend that you call an authorized service center to repair the TV, ask for an estimate.
Good Luck, big IRISH..
ps; the PCB is the center one.
Posted on Aug 07, 2008
Convergence Problem R56W36
Locate the convergence board and get a dot or color generator to throw a pattern on the screen and attempt to converge the three guns. If unable to do, the board is shot.
If handy you can take out the board and checkout the board caps and replace any that have gone bad.
Feb 14, 2016 | Televison & Video
Where is the convergence chip located
Convergence out ICsare located on D Board of Sony KP-46WT510
These are 2 big ICs of black color mounted on silver heat sink.
Check out location of D board in TV in below exploded view...
Aug 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The auto convergence will not realign the picture colors, how do you fix it?
the convergence amps or the resistors have failed on the convergence board. i replace the amps and check the values of all related resistors. it requires good electronics and soldering skill. if you do not have good soldering skills you probally will end up having to replace the entire convergence board
Jul 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
I'm assume you are referring to a non adjustable convergence option. this will occur when you have a damaged convergence chip set that is located on either the PC board or the convergence board. The location of the affected chip will vary from model to model but, in most units, this can be fixed by replacing the convergence board or chip.
May 31, 2009 | RCA HD61W66 61" Projection HDTV
BLUE ON THE MAGIC FOUSCE WILL NOT LINE UP
HI, normally when this occurs, this will signal a malfunctioning convergence chip that is located o the convergence board. this convergence board controls the calibration attempts when syncing the RGB streams.
Simply replacing the convergence board or chip will fix this issue.
May 15, 2009 | Hitachi Televison & Video
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problems
Did you buy the board new or used? It could also be your convergence Ics and not the convergence that is causing the shutdown . The convergence ICs are not located on the convergence Board.
May 21, 2008 | Samsung PCN5425R 54" Rear Projection...
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power board...one color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
