Question about Sanyo DS19330 19" TV
Loud humming noise
Picture is great, so is sound. Humming noise cannot be controlled by volume control. Disconnected from cable, but it still hums. Suggestions?
This problem is sif coil & sound releted 5.5 crustal &releted pf try this
Posted on Jun 21, 2008
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Loud humming after turning on.
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Sep 07, 2009 | Optoma MovieTime DV10 Multimedia Projector
Toyota Highlander with loud humming noise
yes your right... it could be the wheel bearings, try replacing them.
Jul 27, 2009 | 2002 Toyota Camry
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
MY FENDER GUITAR AMPLIFIER IS MAKING A HUMMING BUZZING NOISE
Not sure yet, but before considering a fault with the amp, does it only make this humming noise when not plugged into the guitar? I am thinking that the cable might be faulty.
If it while the cable is plugged in the guitar, does the humming disappear when you turn the volume control(s) down on the guitar? I am thinking that one or pickups may be faulty.
Sep 14, 2008 | Audio Players & Recorders
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Humming noise in Harmon Kardon AVR 110
on what cd dvd ? cheak cable 1st rca swap out
Jan 29, 2008 | Audio Players & Recorders
Sanyo DS19330 19" TV Logo
314 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
