Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Apex gb5108 the picture is only showing wavy blue lines. I took the back off of it and noticed a blue line under one of the 3 cylinder type objects. The other two objects do not have any light coming from them. What could this problem be?
  • GMTRANSPORT1 Jul 19, 2008
    TURN TV ON WE HAVE SOUND WE HAVE A MULTI COLOR WAVY LINE ACROSS THE THE TV SCREEN BUT NO PICTURE
  • llech2 Jul 31, 2008
    have red blue green and yellow wavy lines in a line center of set also have sound?? No picture
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Posted on Jul 10, 2008
Just watching the set, and it turned into a "raindow" in the center of the screen, running horizontal. Sound uneffected . Powerd down and then up, no change.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Apex Digital GB5108 51" Rear Projection...
Come up 3d how to change
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Mar 06, 2010 | Apex Digital GB5108 51" Rear Projection...
Apex gb55108 the convergence is bad ...shows images in 3d form can not set
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 29, 2009 | Apex Digital GB5108 51" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Convergence out of line
STKs must not have held up Look in back of set they are 2 Big Black ICs will have part number on them example STK392-110,if 110s use 150s.you can order parts from MATs 1-800-628-1118.
Aug 20, 2009 | Apex Digital GB5108 51" Rear Projection...
Wavy picture vertically
if you have the speakers on top of the television or a phone near it might becaused by this
Apr 09, 2009 | Apex Digital GB5108 51" Rear Projection...
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
GB5108 picture is collapsed to a blue line in the center
Go to Trinixsoft.com for complete manual. Cost 4.99 for download or 9.99 for shipped cd. I kinda have same problem but my exits with 3 red colors in bowtie form. I think mine is the TDA8351 or vertical control IC. Hope this helps.
Dec 10, 2007 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
257 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
