Question about Samsung Televison & Video
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo Wii on Component 2 it works but screen is in Black and White. I then reversed it and hooked up my Nintendo Wii to component 1 it worked fine. Then I hooked up my DVD player to Component 2 and the DVD player was in Black and White. Any Ideas?
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Posted on Jun 22, 2008
I just bought a Samsun Series 4+ / 440 / 450 (on the users manual lol) but when i try to hook up my DTV or PS3 using an AV cable, nothing shows up. In the Sources, it shows "AV" but when i select...
is that the av channel? if so, how do you know your getting a signal from the ps3? try hooking the ps3 up to something else to make sure you have a signal coming out of that cable (this is where you have to start) if you have another device like a DVD player, or VCR, hook that up to the AV input (or channel one as you say). if you get a picture from those devices, the problem is your ps3 not sending the signals to the tv. sorry I can't be more helpful, but that's my guess
Mar 11, 2011 | Samsung LN-T4053H 40 in. LCD Television
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
Jan 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hi, Can you hook up a dvd player to this model
This model does not have an AV input, just an antenna connector on the back. So you can't hook a DVD player directly to the set. You can, however, use an RF converter. The converter takes the audio and video outputs of the DVD player and converts them to an output on TV channel 3 or 4 which the set can tune in. It's not as sharp a picture or sound as hooking up directly, but it's the only option on your TV. You can find RF converters at large retailers (Best Buy, Radio Shack, Wal-Mart, etc.) and many online stores. They run around $20.
Dec 21, 2010 | RCA F25261 25" TV
How do I hook up a Samsung CXJ1952 to a DVD player? Does it need an RF converter to turn the RCA plug signals into coaxial cable?
it should be the other way around if the tv has av inputs then hook the two units up using av cables if the tv does not have av input then youl need to purchase a rf to av converter
May 15, 2010 | Samsung CXJ1952 19 in. Combo
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
Can't figure out how to get DVD to work.
With no model number of the DVD we will just give a general answer, Many DVD's will only transmit on one output. This means if the menu on the DVD is set to give a S-video signal that is all the DVD will do, Try hooking up every input one at a time untill you get the DVD's menu then you can change to the input you want
Jan 30, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
188 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
