Question about Mitsubishi VS-50705 50" Rear Projection Television
No Power Got a VS-50705 with a no power problem, when i switch it on the power light comes on briefly and then does not complete the post test. The power light last about a second before it goes out. I know it's not much to go on, but if anyone can tell me where to start?
  • 5 more comments
  • Anonymous Jul 26, 2008
    tv comes on for a second then shuts off. Light flashes 3 times
  • kentmitsu Jul 31, 2008
    My Mitsubishi VS-50705 wont turn on. When you push the power button you hear a click and the power light comes on for a fraction of a second but it doesn't turn on. I did the diagnostic and it flashes 2 then 4. What does losing vertical from source mean? Should I bother getting it fixed or is my TV done for?
  • kerradam Aug 13, 2008
    my light flashes 10 times before it stops and how do i know if its a ligth bulb
  • little leon Sep 02, 2008
    I have same problem with VS-50705, when press input andmenu at same time, tv blinks two times twice. It talks about short protect.
  • doerr Dec 02, 2008
    I have the same problem. Push power button and it comes on for less than a second and then turns off again. If I unplug the set overnight and then plug it in right before I turn it on it works fine.
  • knukrazy Dec 27, 2008
    TV shuts itself off and will not completely turn on again. The power light flashes on briefly and then off. When I unplug the TV and plug it back in green on light flashes 3 times.
  • Ron DeVries Apr 18, 2009
    I have a problem as I turn on the TV, hear aclick, green light goes on.
    then nothing. Is it the bulb? Is it a board. TV is about a 1999 but very
    few hours?
  • 927 Answers
Good Day, PCMcGee; To start try these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Jul 17, 2008
My tv won't turn on
Nov 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
set tv on fire,then threw it down the stairs...
now,why would i tell you how i fixed it for 'free' ,when you
charge ''me'' for answers..hmm
Nov 02, 2009 | Mitsubishi VS-50705 50" Rear Projection...
VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
Jun 27, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Vertical bars and lines run up and down the screen. Need service manual or parts outlet
There is no such thing as a "vertical sweep circuit board" in that set. The vertical circuit is part of the sweep module. And BTW that type of symptom is more often a power supply filtering problem anyway.
May 05, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
Power off is when you press the switch.
Shut down is when you turn off from remote and TV stays in standby with led on.
Jul 18, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 convergence problem.
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
Jun 05, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Misubishi VS-50705 50INCH
you would need the service manual to even begin to repair it yourself as it could be literally 50 different reasons why it isnt powering up. I would suggest getting a service manual at the following link , as they will email the manual to you after purchase and then they will provide free tech support to help you diagnose the actual problem , but its a hopeless cause without the service manual. Heres the link.
May 16, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
