Question about Konica Minolta DiMAGE E500 Digital Camera
It will not take a pix or even show a pix to take in the view finder.
Sidebar gone, how do i get it back
Not sure if your problem is in Microsoft or in Apple so here are the steps for both systems:
Microsoft To fix this problem, follow these steps:
  1. Click Start, and then click All Programs.
  2. Click Accessories, right-click Command Prompt, and select Run as administrator.
    If you are prompted for an administrator password or for confirmation, type the password or provide confirmation.
  3. At the command prompt, type the following commands. Press ENTER after each command.Regsvr32 atl.dll
    Regsvr32 "%ProgramFiles%\Windows Sidebar\sbdrop.dll
    Regsvr32 "%ProgramFiles%\Windows Sidebar\wlsrvc.dll
    exit
  4. Restart the computer.
https://support.microsoft.com/en-us/kb/963010
Apple Couple of different approaches could potentially work:
Usually you will just click on the jellybean to get it back. Watch the Youtube video to see how easy this is. If this does not work, try one of the steps below.
1. Close all finder windows so when you click the finder icon it opens a new finder window, one with no sidebar. Then go View>Show Toolbar
Then once the toolbar is enabled, the view/hide sidebar toggle becomes activated in that same menu.
2. Close all finder windows so when you click the finder icon it opens a new finder window, one with no sidebar. Then go View>Show Toolbar
3. Does it show only "FAVORITES" on the sidebar? Move your mouse a little to the right of it, until it says "Show" and press it.
4. If the sidebar is open and items are just missing, then moving the mouse just slightly to the right of the text will reveal a "Show" link.
However, if the sidebar is missing completely from the finder window, simply key option/command/s at the same time to reveal the sidebar. You can also simply hover over View > Show/Hide Sidebar.
5. Click on FINDER, then Preferences. Click on General tab near the top. Half way down "New Finder windows show" (Drop down menu) Click on it.
Choose your scenario. Should work after that.
6. It is possible somehow the Sidebar became hidden by pulling the center bar that separates the Sidebar from the right side viewing pane to the LEFT.
Make sure your Finder/View has Show Sidebar; then try placing your mouse to the far left and see if you get an "i" bar so you can drag it to the right which will make the Sidebar viewable again.
How do restore missing Finder sidebar Missing Finder toolbar and sidebar
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bryan_4d4c18793378ea97
Nov 03, 2015 | Computers & Internet
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Mar 01, 2011 | Fuji FinePix S5000 Digital Camera
Viewfinder views things backwards
Yes, most finder scopes show upside down images, it's completely normal.
This is an astronomical telescope. Even the main tube shows upside down images unless you use what is called an "erecting prism" for terrestrial viewing.
Jul 06, 2010 | Meade 70AZ-TR Telescope
All of a sudden everythig in purple / violet in
There could be a issue with the lens or shutter which is causing the pic quality very bad. kindly get it check
regards,
priti
May 28, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Inverted images of view finder
Yes, nothing is wrong. Most finders show upside down images.
May 20, 2010 | Meade 70AZ-TR Telescope
I cannot see through the viewfinder of my new fuji finepix 1500
The EVF/LCD button on the back switches between the lcd or the Electronic View Finder. Basically it's a small screen acting as a view finder
Sep 17, 2009 | Pix FUJIFILM Fine S1500fd Digital Camera
Fuji fine pix s800 - have to use view finder to
Press the button marked "evf". That should move the image to the big LCD for shooting.
Aug 10, 2009 | Fuji FinePix S8000fd Digital Camera
Fuji FinePix F710 photos blacked out
hi
i think the settings on the exposure or apparture have been modified
reset the camera to factory defaults once to check this and you can have the photos back in order
happy clicking, enjoy
pls rate if this was any help
Jul 13, 2009 | Fuji FinePix F710 Digital Camera
Can't upload pix
when u turn on the camera is the view finder black?
Sep 05, 2008 | Nikon COOLPIX L4 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
21 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
