Question about HP Photosmart 2610 All-In-One InkJet Printer
Will not operate
All 4 green lights keep flashing and unit will not turn off.
    Problem Solver:
  • 12 Answers
** Verify that the product is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the all-in-one product have a three-prong power plug.
2. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
Power Cycle:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en
Posted on Jul 07, 2008
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Controller 4 blinking lights continously
Hi, of the multiple errors that can strike the PlayStation 3, you may one day have to fix the PS3 green light flashing problem. This issue is perhaps one of the most antagonizing for the average user. The unit appears to power up for about 3 seconds and then shuts down before the system has a chance to boot. When this happens you need to fix PS3 green light flashing problem in order to get your console working again.
Simple Ways To Repair PS3 Green Light Flashing At Home:
In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Have a nice day.
Sep 15, 2010 | Sony Playstation 3 (PS3) Console
At start up the green light turns yellow red light flashes and system powers down. What should I do?
Hi,In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Have a nice day.
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
My new TV keeps turning off and then on again with flashing red and green lights in front.
Check your warranty for the unit. Then call Samsung to see I they can help.
800-243-0000 Customer Support
If no help there repost with model # of the unit.
May 15, 2009 | Televison & Video
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
