Question about Brother MFC-8840D All-In-One Laser Printer
DX Lever Error
What does that mean? how do I fix?
  • 3 more comments
  • bonfiregrand Jun 21, 2008
    what is the duplex lever
  • Anonymous Jun 24, 2008
    on which part of the machine we can find
    DX lever
  • ishika Jun 25, 2008
    i have a Dx Lever error in my machine, so i cant do the photocopy, please can you help me out ... how can i fix and start doing th photocopy....
    i cant do back to back photocopy, not even fax and not even printing... so what is the solution ........
  • Anonymous Apr 29, 2009
    This was amazingly helpful!!  Problem solved.  Thanks - mml
  • 85 Answers
This message indicates that the Duplex Lever is located incorrectly. To clear this error message, please check the location of the Duplex Lever and relocate it to the correct position.
Posted on Jun 21, 2008
Model DX2430 printer. What does E-12 error mean?
E-12 Pressure Plate error
See if the springs( C252 3556 Spring:Pressure:Master Ejection:13.98N)is still attached on both sides of the pressure plate.
Ricoh DX 2330 2430 3343 Service Repair Manual
Jan 23, 2016 | Office Equipment & Supplies
I keep getting error code NVRAM err=0x10, what does this mean?
HP Printers 49.XXXX Service Errors ' Market Point's Tech ...
blog.marketpoint.com/2010/07/29/hp-printers-49-xxxx-service-errors/
Jul 29, 2010 - In this article, I'll discuss the meaning of the error, what causes it, and gives ... changes with the firmware or other parts to prevent the error from recurring. ...fixes for a few printers and was surprised to see several 49 errors being ... try a cold reset or NVRAM initialization (see service manual for details).
A wifi spot named "NVRAM WARNING: ERR = 0x10" - DealExtreme Forum
club.dx.com/forums/forums.dx/threadid.1136935
Mar 11, 2012 - A wifi spot named "NVRAM WARNING: ERR = 0x10" ... It has the sameerror, both in wifi settings and in the wifi Analyser app. I did obtain the ...
57.1 printer error - HP Support Center
Dec 17, 2015 | Office Equipment & Supplies
My canon MP480 keeps poping up a 5100 error
That error is a Carriage error, which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Make sure you've installed the cartridges correctly and that the grey lever that holds down the printhead is in the down and locked position.
You may find that you've installed the printhead incorrectly so worth pulling out the cartridges, removing the printhead and then reseating it so the lever goes down to a horizontal position. Then reinsert the cartridges.
Mar 10, 2011 | Canon Pixma MP480 All-In-One InkJet...
What does error 02 mean on a epson dx 6000 printer mean
The ink cartridges is already damage if you have tried refilling the ink cartridges several times
Nov 24, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus DX 8400
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
My brand new printer is displaying printer error code 5100 and will not print or recognise the ink not sure if this means the ink cartridges are faulty.
That error translates as a "Carriage error"... which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Check you've installed the cartridges correctly and that the grey lever that holds down the printhead, etc.. has been put in the down and locked position.
If that doesn't solve it the best course of action is to return it and demand a replacement.
Feb 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Konica magiclolor 2530 DL Fatal Error 1bh
Basically the fuser is not operating properly. This fault can be caused by 1 of 4 things. The fuser itself, the engine control board, DC power supply unit or the fuser safety switch lever hinge. The easiest to check first is the hinge. Disconnect the power cord and remove the Left side cover. Beneath this is a boomerang shaped lever arm with a pivot in the middle. As this pivot is plastic it can break over time. if you can source an appropriate self tapping screw, this can effect a repair.
Nov 03, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Where is the dx lever?
There is a lever on the back of the machine. I had this same error message, and I just moved the lever to the opposite side. The first time I moved it, items printed on single side still in the cue came out. Immediately after it printed, the DX lever message appeared on the error screen again. I went back and switched to to the other side, and then my duplex copies in the cue started to print. So far so good. Somehow the duplex feature was manually shut off. My husband was printing office checks at the time, so this might have triggered something, since the checks cannot be printed in duplex mode.
The Brother is a little clunky of a machine. So...even though the duplex lever in the back isn't marked, and I couldn't find the info in the user manual...this seems to be the only thing that's manually adjustable on the machine.
Hope this helps!
Aug 27, 2008 | Brother MFC-8840D All-In-One Laser Printer
Toner problems
I've had this problem several time. Usually I fix it with a q-tip!
Open the top of the printer and locate the correct toner cartridge. Pull the (blue) lever on the right side of the cartridge toward you to disengage it from the drum. Gently life the toner cartridge out of the printer.
On the right end (the end with the blue lever) there's a small slot. You should see some white plastic in there. Use the qtip to clean off any dirt or toner.
Now replace your toner cartridge and slide the blue lever back to the original position. Close the top.
This USUALLY fixes the problem. (I must stress "usually" because I'm having the problem right now and this procedure won't fix it, but I've fixed it with this method a dozen times before.)
Jul 28, 2008 | OKI C5150n Led Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
849 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
