Question about Sanford MARK II Tripod
I have a 270 semi auto from 1969 which the seller said it had only been fired 5 times in that period, i have since put 40 rounds through it and it keeps jamming ive tried remmington,winchester and federal ammunition and they all jam i did take the gun a gunsmith for a good cleaning but it still jams any idea as to what can be done to fix the issue,
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Check the magazine spring; the weapon was probably stored with ammo in the mag, and the spring has lost its elasticity. Try a different mag and see whether it resolves the problem. Other possible issues: inadequate lubrication, a rough spot on the breech block that's catching the cartridge, or carbon buildup immediately inside the breech.
Posted on Dec 02, 2017
2 Suggested Answers
SOURCE: primer failure with federal ammunition
Blown primers and hard ejection are clear indications of excessive pressure. If these are handloads you need to back off on the charge and possibly make other changes in your load. Check a good loading manual for reference.
If they are factory loads you perhaps have a headspace problem or the oal with that particular bullet is too long for your particular rifle, jamming the bullet into the rifling, and not allowing it any "jump space" or lead.
1. dont fire anymore of that lot of ammo, and contact federal.
2. check with a qualified gunsmith, have headspace, and bore diameter checked.
3. if your knowledgable in smoking the tip of a bullet, check for lead, or have this done by a qualified gunsmith.
Posted on Aug 04, 2009
In search of a 10 round magazine for a Remington model 7400 semi-auto ,30/06 I don'twant after rmarket.I've tried them and do not work
not sure if this link will help you out,but at the top of the page its saying ebay has some...pluse if you scroll down the same page there is others selling them.hope this helps you out.... 10 round magazine for Remington model 7400 semi auto 30 06 Google Search
Oct 24, 2017 | Remington Garden
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
Mod 110 270 when i pull bolt back and load round push bolt forward round fires ?
Gunsmith call, Firing pin is sticking in the bolt or sear is worn.
Jan 19, 2017 | Cars & Trucks
What oil do i put in a 1996 ford courier 2.6 petrol
you did not post in what country and what climate,
if you are in oz, then any oil sae10-40, it is suitable year round,
if you live somewhere where water freeze in winter then winter oil should be sae 5-30, or sae5-40, summer should be sae 10-40,
if you live in tropics where temperature constantly exceed 35c (95f), then oil used should be sae15-60 or even sae20-60.
any brand will do, my preference is semi-synthetics in cars made after 1985, if car is working hard - towing, driving daily short distances - i do change oil and oil filter every 5000km (3000miles), if it is driven regularly and in light conditions you can double these distances.
if you find this answer helpful - why do not vote for it?
Jan 14, 2015 | Ford Cars & Trucks
Distributor firing order for 1969 olds 350
1969 Oldsmobile Cutlass 5.7L 4BL OHV 8cyl
The Firing Order
.Firing order 1-8-4-3-6-5-7-2 ---------front ' 2 4 6 8 ' of ' ' distributor rotates counter vehicle ' 1 3 5 7 ' clockwise---------
Sep 16, 2013 | Oldsmobile Cutlass Supreme Cars & Trucks
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
Jun 15, 2011 | Chevrolet Corvette Cars & Trucks
I have a used custom 98 ACT platinum. When i fire it , it goes full auto. My speed is at 270 fps.What do i do?
Buy a oil for a few dollars made specifically for paintball. Put a few drops in the ASA(where the tank screws in) screw the tank in and try to fire it about 10 times. If the gun still goes FA or sputters, I highly recommend having it serviced by a local pro shop or Tippmann.
Mar 29, 2011 | Tippmann 98 Custom Act Paintball Gun
I HAVE BUILT MY FIRST SKS (YUGO) AND IT WILL NOT SHOOT IN SEMI-AUTO I HAVE USED A NE GAS VALVE NEW GAS PISTON NEW GAS TUBE AND OPP ROD AND SPRING
If your rifle reloads a new round but will not fire it is a problem with the trigger mechanism, if it does not reload a new round but locks back like the clip is empty, you have a problem with the clip spring not forcing a new round up hard enough to feed, if it cycles the receiver and does not pick up a new round your recoil spring is to strong or you need to open the gas port some more.
Feb 07, 2010 | Optics
Sanford MARK II Tripod Logo
402 people viewed this question
Top Sanford Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Sanford Photography Expert? Answer questions, earn points and help others
