Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra CB After squeezing my microphone to speak I get talk back in my stereo speakers and a screeching noise
  • 27 Answers
You are getting RF feed back..this can be controlled by the dynamike controll, also you may have the cb mounted close to your stereo. The best way to install any tx/rx is direct connect to you battery (both + and , and suffers from low receive output
(should be about 3 watts) I suspect dried up electro caps is the
problem, as there are heaps in this set as well as heaps of tantalum electro caps (electrolytic capacitors) These cause the set to drift off frequency / power
GOOD LUCK FLYINGFOX@PEOPLE.NET.AU
Posted on Jun 22, 2008
  • flyingfox Jun 22, 2008
    SORRY MATE MADE A BLOODY MESS OF THAT POST !!!!
    You are getting RF feed back, you should be able to stop this
    by using the dynamike control. Also , the best way to install any tx/rx is both the + and - leads direct to the car battery using an inline fuse. i know these sets, and they are a bugger to generate" whistleup" and also suffer from low voice output.I think
    the problem is they have such a large amount of electrolytic capacitors (including tantalum) and the electrolite has dried up with age causing power down ,and frequency drift. (98% of the parts in these radios are freely available in stores like **** Smith
    or Jaycar Electronice but would be a long job to change all of them, and that may still not fix any problems. But , if you have electronic skills it can be done. because the circuit board is densely packed IT WILL NEED SKILL AND TIME.
Cobra highgear hg75m mic squeals
get it away from the ext . speaker. They are cheap enough ,buy another one and see if it still squeals. If it does then you may have to jump the mic with resistors ,turn down your mic gain, check for talk back on rear where your pa. and external speaker hooks to inside the radio. If you see a resister connecting them then you have talk back . Mainly its a Keep the mic away from the speaker deal that makes them squeal. Try other cobra mics with the same pin out and see if it still happens . easy fix just have to be patient .
Feb 06, 2014 | Cobra 29 LTD CB Radio
What dose the T back button do for the cobra 29 lx cb radio
That usually is for "Talk Back". When you speak into the microphone you should hear yourself in the speaker.
Feb 26, 2013 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Everytime i try to speak to someone they here a screeching noise at there end and cant make out what im saying, but i can here them ok at my end, ive changed mics so i no its not that, would it be my ariel...
Make sure that you are both on FM or USB If the modulation is not the same then you have a bad communication. If you hit the mike and they get a santia 9+ then the arial cannot be the issue
I assume that you have tested it with a mike that was supplied with the cb?
good luck
rene
Jun 08, 2011 | Cobra 29 LTD CB Radio
When I speak on my cobra 29 nw, I can here my voice on my stereo radio speakers. Any ideas what causes this?
too much power or you are overmodulating.....i.e. power nmic ? ?
If you place a .05mfd cap across yoy're speaker terms.they will help that problem also...Good luck ! !
Oct 03, 2010 | Cobra 29 LTD CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Modulation style woodspeaker
i am not sure what a wood speaker is ,unless you're talking about a home speaker.if you are coming through stereo
speakers take any excess wire on the speaker and coil it up as many small loops as you can and tape or wire tie them.this creates a trap.this works on just about any thing picking up you're signal.
Aug 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
I don't have voice, have carrier. Cobra 29 ltd
there are several things that might be responsible for the absence of modulation when speaking into the microphone. a defective mic cartridge, a broken audio or audio shield/ground wire in the mic cable or mic plug or a defective push-to-talk switch in the mic itself, for starters. if all is well here then the amc and transmitter speech stages in the transceiver will have to be considered next. locate and check with a known good mic wired for the radio in question. let me know.
Jun 06, 2009 | Cobra 29 LTD CB Radio
No Transmitting, no RX sound, but can hear speaker click on...
Hi there!!
The symptom sounds like a bad Microphone connection or a bad microphone!! The Cobra has a built in circuit that wont allow you to hear anyone until the microphone is plugged in and the no transmit part will also do the same. Try another microphone that is wired right for that radio before you do anything else!! let me know!!
Dennis
Mar 18, 2009 | Cobra 29 NW CB Radio
I purchased a s500 Talk-Back speaker. There was not paperwork included with the speaker. Which wire is the PA. I am thinking it is the small red wire. Also: in order to use the Blue Tooth function of the...
It is the small red wire that goes in the PA, or you can just ground this wire. The bluetooth will work through the stock microphone.The external mic is for handsfree use.
Jan 15, 2009 | Cobra 29 LTD CB Radio
Losed all
The talk back may be nothing more than a 10 ohm resistor shorted across the pa/external speaker outputs. If this is the sitution, the resistor may have damaged the audio chip. Remove the resistor and see if this corrects the problem. If not you may need to replace the audio chip. Hope this helps
Ed
NC Electronic
Mills Wyomign
Jan 06, 2008 | Cobra 29 LTD CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
96 people viewed this question
Top Cobra Radio Communications Experts
Iron
Iron
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
