I've captured a PAL movie and am trying to convert to NTSC with VSO ConvertX2DVD when I get the following error: Stream #1 delay (95443357.69 ms) is to big, your video file is not correctly multiplexed. How do I resolve this issue?
  • 6,487 Answers
Try upgrading your convertX2DVD to the latest one I believe its 2.1.5 that should solve it.
Hope its helps...........
Posted on Jun 21, 2008
    Sergeant:
    Champion:
  • 347 Answers
Hello BigBont;
I sueest you to try another program to convert the videos.
Dowload this program and try it. Let me know if it didnt worked
http://www.alivemedia.net/download-video-converter.htm
Good luck
Dahaka
Can i convert at PAL video with this machine?
The version of the ZV427MG9 sold in the U.S. only supports NTSC video files. Thus it won't play a PAL VHS tape.
If you find a similar version sold in Europe, that would probably play PAL videos. However, if you used the tape to DVD dubbing feature, the DVD would still have the PAL format. I'm not even sure that a video capture device with video conversion software on a computer would do what you want to do.
I wish that I had better news for you.
(The video would also matter. If you are trying to convert a commercial video (ex: a movie) to DVD, the dubbing feature doesn't work due to copy protection.)
Feb 14, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
May 09, 2013 | Fulltone Ruby GrabBee Deluxe USB 20 NTSC...
How to convert sanyo dvr DSR300N(NTSC) to DSR300P(PAL)?
You have to buy one NTSC to PAL signal converter for this, and connect it in beween your tV and DVR.
Apr 21, 2012 | Sanyo DVR-120
Hello! thnx for assisting me! I am having problems connecting my canon zr20 mini dv camcorder with the laptop.I got my camcorder in the usa but I live in europe and im having problems also converting from...
Most laptops use a 4 pin firewire connection as does your Canon.
Get a 4 pin to 4 pin firewire cable to connect. I assuma it's a PC and not a Mac, so use Windows Movie Maker to capture.
All editing applications can be user selected for PAL or NTSC, so stick with NTSC in MMaker.
You cannot convert video standards sucessfully simply by selecting PAL if the source is NTSC. You require specialist software or hardware conversions.
As a side point if you create an NTSC DVD it will play on PAL equipment.
Mar 04, 2011 | Canon ZR20 Mini DV Digital Camcorder
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
NTSC to PAL
I am under the impression that your computer has a PAL video capture card. Being a laptop, it is probably built in to the mother board.
What your computer requires is an NTSC video capture card that can also handle audio as like the PAL one that is in the computer.
I would suggest you go out and get a USB type NTSC video/audio capture card. After loading the drivers and software for the new card, it should be able to accomplish your task.
Jerry G.
Oct 02, 2008 | Panasonic VDR-D50 DVD Camcorder
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
