Replacing Motherboard My Gateway GT4024 desktop won't boot and monitor doesn't connect. Same monitor works on different PC and because the video card is part of the motherboard I assume the motherboard is broken. I took it to Geek Squad they diagnosed the same. They don't replace motherboards. So if I purchase a new motherboard (MS-7248) how hard will it be to do it myself? I'm not 100% sure that it is the motherboard but when I power it up with a new video card in it, the monitor shows Gateway but doesn't go through the boot process. The hard drive fan is running. The motherboard will cost about $200 delivered. Should I replace the motherboard or just buy a new computer?
  • juliecbf Jun 21, 2008
    Thanks edric.  I decided I can't afford the downtime or risk creating more problems so I took it to a computer repair place but don't know what they have found out yet.
    thanks again!
Thought I would close this out by reporting what we found. When I removed the CD drive I bumped the memory just a bit out of place which caused all the trouble. Luckily my tech guy methodically thought through and tested all the possibilities before just buying a new motherboard or new computer. I was embarrassed that that is all it was but also very relieved...I guess that's why you call an expert.
Posted on Jun 22, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
There are things to consider when buying a motherboard.
  1. The type of processor you are using must fit on your new motherboard (compatibility issues)
  2. Memory.
Better ask your local store for a compatible motherboard. Unless your going to buy the same board .
If your purchase a new motherboard it comes with a instruction manual complete with installation guidelines and illustration to help you out. In case you have trouble doing so you can always contact your vendor or the manufacturer for help (online, toll free numbers).
If your having doubts whether your motherboard is defective you can run tests but you will need extra parts. You could ask your friends if they have one. In my case I usually test other components ex. processor, memory with a spare working motherboard. Fit in the componenets with your spare motherboard and if it runs chances are your suspected board is defective. Or better have it checked at another service center for a 2nd opinion.
Posted on Jun 21, 2008
  • Edric Rojas Jun 21, 2008
    Thank you for rating my solution. Glad to help
Gateway computer is stuck in power saving mode.
The Gateway 818GM is a few years old but if - hopefully - the motherboard auto-detects a video card, try removing the MSI MS-8936 video card & swapping over the monitor lead to the other VGA connector fed from the motherboard.
Failing that, if you think it's a faulty video card, they're cheaply available on eBay eg for US$6.70 here:
MSI NVIDIA GeForce MX 4000 MS 8936 64 MB DDR SDRAM AGP 4x 8x Graphics
Feb 21, 2014 | Dell Dimension 3100 PC Desktop
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
I have a Gateway E2000 pc....monitor and pc are not communicating...I hear windows boot up so the pc is working. I've changed cables that worked for a while. Now I'm thinking I need a new video...
Not sure how reputable these guys are, but here's something at least...
http://www.memorygiant.com/video-card/gateway-e-series-e2000-deluxe/
Also, make sure that you're buying PCI cards, and not PCI-e.
May 27, 2011 | Gateway E-2000 Deluxe PC Desktop
I have a gateway gt4024 and was trying to find out if I am able to upgrade the existing MB, CPU and Graphics card without getting a complete tower.
No, the motherboard is a proprietary format, specific to just this model and the case was designed around it.
http://support.gateway.com/s/MOTHERBD/MSI/4001071R/4001071Rnv.shtml
Jan 26, 2011 | Gateway GT4024 PC Desktop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
I have a Gateway GT5056, no monitor will work.
The video card you have is integrated into the motherboard. You would have to buy a whole new motherboard to fix the problem. It would almost be cheaper to buy a new computer though.
Sep 21, 2009 | Gateway GT5056 PC Desktop
Video card upgrade for Gateway GT4024
Try looking up for Updated drivers at Gateway for your Computer. Also find out what video it's using (ie. NVidia, Radeon, etc.) Many times the Video Card maker will have the latest updates for video cards before they get to the computer maker.
Jun 10, 2009 | Gateway GT4024 PC Desktop
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Monitor is black when computer is on
Make sure your video card is properly seated on the motherboard. Also, it might be a good time to open up your case and blow it out with compressed air. I use an air compressor. Sometimes you need to reseat the hardware. If that doesn't work you might have a faulty video card.
May 28, 2009 | Gateway GT4024 PC Desktop
Computers & Internet Logo
676 people viewed this question
David Payne
David Payne
