Question about Acer Computers & Internet
Nootbook lcd repiar
Dear sir my laptop lcd is gaving colour white if i keep one side is gaving colour right
    Problem Solver:
  • 17 Answers
It is possible your LCD has a problem. If
If none of the adjustments such as brightness, contrast and color have been tampered with, then it is advisable it be looked by an expert.
LCD are sensitive to too much heat and pressure. My recommendation is confirm that none of the above adjustments have tampered with and if none then consider a review by an expert as they are delicate and complex to remove.
Good luck.
Posted on Jun 21, 2008
Sir, i want to my laptop Sony vaio
white screen indicates either:
i. lcd cables gone bad.
ii. the logic board fried.
neither, you should replace the whole lcd.
Oct 10, 2013 | Sony Vaio Vgn-c290 13.3" Lcd Wxga Laptop...
Right side of laptop is Dim and Fuzzy
Yes it's the back light in the LCD> There are small light bulbs behind the LCD and they are responsible for the light that you can see. The ones on the right side should be bad. You need to get it serviced or replace the whole LCD screen.
Feb 21, 2013 | HP Computers & Internet
No display,only bright wihite colour screen
which brand of laptop ?
What can you do if the laptop LCD screen turned completely white?
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Here's an example of a laptop with white screen.
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor.
Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen.
If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen.
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Sep 23, 2012 | Computers & Internet
Colour gone on my 32" lcd televion
Possible that there are issues on your cable or RF input. check and see if the COLOUR SETTINGS are chosen for the right colour system if not you can manually set the system or reset with auto tuning and auto colour detection. Since there is colour with the satelite channel-- hope it is given to the AV inputs- then the RF signal/IF processs side also needs to be checked for loss of chroma signals or processing.
Nov 15, 2011 | Televison & Video
Sir, I am using Acer Aspire 4530 laptop. About 3 days ago I unplugged the main power supply. The laptop was running on battery. After an hour all of a sudden there was blank screen. I can seen black and...
You must have hit the screen and damaged it, that's the only way you get those colored lines. Contact Acer tech support for assistance in replacing the LCD. You will have to go through a bit to get a phone number. http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Contact+Support&brand=Acer
Mar 05, 2011 | Computers & Internet
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
White line on screen easynote mv35-202
Replace the LCD screen. Its problem with the LCD panel.
Sep 07, 2009 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
