Question about Gateway 505GR PC Desktop
Hard drive I accidentally disconnected my hard drive while installing a memory upgrade. All the connections I could find are reconnected, but it cannot reboot. How do I properly reconnect the hard drive. Thank you
    Sergeant:
  • 458 Answers
The hard drive cable is either red if it is a SATA drive or WIDE WHITE cable if it is IDE.
On the back of the hard drive you will see a bunch of pins if it is IDE.
If it is SATA it will look like an L shape. The power plug goes in the 4 prong slot.
The boad will have the same looking connections.
If you can not figure it out give me the serial number off of the hard drive.
Posted on Jun 21, 2008
    Brigadier General:
  • 6,966 Answers
Physical connection would depend whether you have a SATA or an IDE HD as their data interface/cable differs, however the power would roughly be the same and/or would be using an adapter. Additionally, it may require that you auto/manual detect the HD in the BIOS/CMOS and Save before rebooting.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Sergeant:
  • 260 Answers
Dtbdb,
thanks for asking us.
it sounds like you disconnected the hard drive, then reconnected it, and you still cannot reboot.
I recommend that you unplug the machine, unplug the memory card you recently inserted, unplug and then re-insert the connection to the hard drive, then reboot. Once you have successfully rebooted the computer you can then unplug it again and try adding the memory again. Make sure all connections have been returned. Also, make sure you have not disconnected the power supply from any of the components.
Good luck :)
  • Gateway Master
  • 6,487 Answers
You can check this link for the step by step way to reconnect your hard drive: http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
Hope that helps.....
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Dane elec portable hard drive not recognised by win 7 pc
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted.
If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off."
Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive.
Connect the cord directly into an outlet and power up the drive.
If the drive is powered and still not working, check the data cable.
Power down the hard drive and disconnect the data cable from the computer.
Wait 30 seconds to one minute.
Reconnect the data cable and power up the drive.
If the drive is not detected, power down the hard drive and connect the cable to a different port.
Power up the drive.
If the drive is detected but not working, check for a missing driver.
Click on the "Start" button, right-click "Computer" and select "Manage."
Enter your administrator password if requested.
Select "Device Manager" and double-click "Disk Drives."
Right-click the yellow exclamation point and install the missing driver. Close the Device Manager.
If the drive is detected but not working check to ensure it has an assigned drive letter.
Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer.
Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested.
Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add."
Assign a drive letter.
Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window.
If the drive is detected but not working, check whether the drive is in sleep mode.
Click the "Start" button, right-click "Computer" and select "Manage."
Select "Device Manager" and double-click "Universal Serial Bus Controllers."
Double-click the first instance of "USB Root Hub" or "Root Hub."
Check for the hard drive.
If the drive is not visible, move to the next instance of "USB Root Hub."
Continue checking each instance until the hard drive is located.
Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager.
Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
How to open and change RAM memory and hard drive on Gateway Netbook model number LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
Mar 01, 2011 | Computers & Internet
Mon pc ne reconnais plus my boock
Please try to disconnect and reconnect your usb hard drive is this hard drive working normally before. Try also another usb connection like flash memory to check your usb connection. If there is no problem with other hardware you may have your usb hard drive malfunction.
Regards, Jay
Feb 15, 2011 | Western Digital My Book Essential Edition...
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
I had to replace hard drive in my thinkcenter
Chances are when the repairman was installing the hard drive that they accidentally unplugged the floppy drive. You will need to contact the repair guy and have them correct the issue.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 14, 2009 | Computers & Internet
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
Cables need reconnected inside my gateway gp7-600
It may be easier for you to read an ide hard drive primer, here's the first one that comes from google:
Jan 25, 2009 | Gateway Computers & Internet
Memory upgrade
There are 2 memory slots in Acer L320. You can use program called cpuz to check how many memory modules are you using, and what size are they.
If you have any module free you should be capable to upgrade memory.
May 31, 2008 | Computers & Internet
Connecting Multiple Drives and new graphics card
1st issue...you can get an adapter to extend & spit one power plug into two at a very low cost,
2nd issue...if it is not causing any problems ,the next time it comes up, sellect "donot show again"
good luck
Terry
Mar 12, 2008 | ASUS A7S8X-MX Motherboard
Gateway 505GR PC Desktop Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
