Question about KB Gear Little Tikes kidBoard Keyboard
Software Hi, My daughter has managed to destroy our Kidboard Coach software disk that came with the keyboard. How do I get another one??
From hell!!!
Posted on Jun 21, 2008
I purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
My wireless mouse is working fine,but my wireless keyboard is not. I tried pushing the connect button on the back but it didn't help.
Every device has a piece of software called driver. Without driver no hardware can function as desired. Therefore, go to device manager and see whether the wireless keyboard driver is functional. If it is not then it will show up with a yellow question mark. Then insert the driver disk into the drive and right click on the yellow question mark and select upgrade driver and locate the driver disk and install it. To go to device manager do the following:
right click on the My Computer icon and select Manage option.
Aug 30, 2010 | Logitech Computers & Internet
Keyboard works, but CD needs Windows 95 to support
does that unit have a large jack on the end.
If so there is a AT to P/S2 adapter
With the P/S2 adapter Vista should see it because you plugged it in the keybouard port
Give it a try
Jul 21, 2010 | KB Gear Little Tikes kidBoard Keyboard
Wyse x90 xpe formatting/back to factory settings
you can get a program from avanquest to wipe out the hard drive like this one
http://www.avanquest.com/USA/software/drive-erasepro-99105?meta=pc-utilities&cat=disk-management-disk-partition&sub=erase-disk
and there other program will partition it
http://www.avanquest.com/USA/software/partition-commander-11-126553?meta=pc-utilities&cat=disk-management-software&sub=hard-disk-software
I use there products to wipe and reload any time that i need to.
it is easy to use put the cd in the dvd and make sure the bios is set to boot to the cd rom first then hard drive.
then follow the on screen prompts after it boots to disk.
Jun 13, 2010 | Computers & Internet
Driver and software loaded but when I run the software it says "Device not Ready." Device manager thinks it's a "Coach" digital camera.
open device manager
start>run>devmgmt.msc>ok
rigth click on the Coach digital camera and update driver let windows search the inter net for the soft wear. if you are unable to find beter softwear try to uninstall the camara and restart your system then plug in your camara in device manager you should see it conect rigth click and update driver aviod searching your system hope this solves your fault
Dec 18, 2009 | Largan Mega 2 Digital Camera
Pc will not recogize the keyboard and I can't find the game disk
You need to look online for "Free drivers" for the keyboard. You should be able to easily download the driver and hopefully that will solve your dilemna.
Nov 02, 2009 | KB Gear Little Tikes kidBoard Keyboard
Daughter accidentally cut software installation disk opening it.
My daughter cut the software as well. 5.1 MP Digital Camera. Can I buy the installation disk only somewhere.
Dec 27, 2008 | Sakar Digital Camcorder
Worm
Hi there
If you have a worm virus in the system then you will never get rid of it!!
If you have managed to stop it in its tracks download "spybot search and destroy" this is free software and will locate the worm virus and hopefully destroy it, you can also try AVG8 this is also free software, before you use this software you must firstly unistall the old antivirus software
kind regards
Dec 22, 2008 | Avanquest System Suite 8: Windows
KB Gear Little Tikes kidBoard Keyboard Logo
109 people viewed this question
Top KB Gear Computers & Internet Experts
John Anderson
John Anderson
thegtw
Clif Roberts
Are you a KB Gear Computer and Internet Expert? Answer questions, earn points and help others
