FixYa.com
Tags:
Lexmark X73 All-In-One InkJet Printer
X73 found loose spring (by 3 users)
posted by beachweave on Jun 21, 2008
My x73 wasn't feeding paper and I took it apart to see if I could fix it like suggested here. When I got it apart a small black spring fell out, about the size of one of the screws. does anyone know where this little spring came from? maybe I can still fix it.
jw
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by jroma101, posted on Aug 19, 2008
Paper was advancing irregularily, resulting in printing one line on top of another. In turning the machine over to look inside for jam, a silver spring about 5/8" in diameter and 1" long rolled out of the paper feed slot. Looking for parts diagram or exploded view to find the home of this spring.
Comment by hamnxz, posted on Jul 27, 2008
My X73 stopped feeding the paper. I took it completely apart and found a broken spring under the catridge bed. In additon a silver screw was jammed into the paper moving gears. Could not find where the screw belonged. Took both out and did a good cleaing. I sill have the same problem.
Solution #1
Not Rated (0)
oldtymertech
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
that spring and screw need to be replaced where they came from..factory level repair
Try this link for more Printer Resources
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
printer won't print
I have installed two new ink... Answer This...
PRINTER NOT WORKING
Had a paper jam; now printer... Answer This...
enable directiional support
I accidentally hit the wrong... Answer This...
can't get printer to work on my...
I go through all the set up... Answer This...
LEXMARKX73
getting lite to comeon but it... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
