Turned on HDTV Model# DP19647,Serial# B7320217928212. The picture came on fine and then the screen went white. Tried reset button on remote but nothing happened. This was purchased in Oct. 2007, not yet a year old.
  • Ken Jones
    Ken Jones May 11, 2010
    Hello nanniepat, thanks for contacting us.
    Does your television make any noise when the screen is white?
    Thanks for your question.
    Sergeant:
  • 260 Answers
Good. Thanks for asking us for help
Posted on Jun 23, 2008
Call Sanyo and it was under warrenty. Thank you
Posted on Jun 21, 2008
Why did my sanyo 19" hdtv all of sudden went black? what to do now?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 12, 2014 | Sanyo DP19647 19 in. LCD TV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
White box on tv screen
This sounds like your picture in picture feature is enabled or turned on. There is a button on the .ca remote that says pip or you may find it under the menus
Nov 23, 2012 | RCA HD52W59 HDTV Projection Television
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sanyo DP19647...power comes on but no picture on screen. Any ideas?
Main Power Board is damaged, you have to replace but it´s an expensive part maybe the best is to buy a new TV
Sep 05, 2009 | Sanyo DP19647 19 in. LCD TV
Vizio VW32LF powers up no sound no picture unplug to turn off
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jun 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
