Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Bizhub c351 Hi there, I still cant add the printer to my powerbook. Im not sure if I have the correct driver, because the cd I have dont have it, so I downloaded from the minolta site. Where can I get the correct driver for this printer? I wont set it up with a network, it will be straight from the computer. thanks
  • alejandro01 Jun 24, 2008
    thanks very much. Ill download it and check if it will work.
    Hi Kevin,
    I downloaded the driver, and when I try to install, it tells me that I have a newer software. The problem is, that with whatever software I have installed, it does not recognize the printer.
    I also get confused with which version should I used, the normal c351 or the IC-402?
    thanks
  • 167 Answers
Help.bt.konicaminolta.ca
Posted on Jun 23, 2008
I have a C351. I have changed the network in the office and now when I print, I don't have the option of Standard BW. How do I get that option back.
did you have to reload the drivers on the server?? if so then there is an option tab on the driver that you have to enable the features of your bizhub.
Sep 26, 2011 | Konica Minolta bizhub C351 All-In-One...
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Aug 16, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
May 01, 2009 | Konica Minolta bizhub C351 All-In-One...
Desktop faxing from Konica c351
Go to this link to get the fax drivers you need.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=827&filetypeid=0&osid=3
You should have had a cd that came with the machine that has them as well. Once they are installed, go into Microsoft Word and select the fax to print from. A screen should appear asking you for the phone number of the name out of the address book.
Sep 26, 2008 | Konica Minolta bizhub C351 All-In-One...
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Mar 13, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
123 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
