Question about Nintendo DS Console
Can i do you have a shop or something so i can bring it to you cause i don't want to brake anything so can you do for under $60.00 which includes the top and the bottom screen?
  • madison95380 Jun 21, 2008
    can you put the top and the bottom screen on cause i don't want to brake anything.
  • 61 Answers
Try ebay $40.00 under repair service
Posted on Jul 18, 2008
My back brakes on my Oldsmobile ciera sl won't work. how do i get them working again?
Bring it to a certified repair shop. When you don't know what is wrong, you certainly won't be able to repair this baby.
Can be anything from bad disks, shoos, leaking break fluid, to name just a few of the hundreds of possible causes.
Mar 17, 2015 | Oldsmobile Cars & Trucks
Why abs and brakes light on after few minutes drive after rear wheel brakes service
Could be a lot of things that would make this happen. If the work was done at a shop, bring it back and have them check their work. They may have neglected something. A good shop will not charge you to inspect what they did.
If you did the work yourself, you may have forgotten something, or maybe installed the wrong brake parts.
In any event, bring it to a Authorized Honda store and have them check it. It could be something really simple. It would be better to be safe than have the brakes fail when you need them.
This is a safety item, DO NOT CHEAT!
Have someone check it.
Jun 17, 2014 | 2007 Honda Civic 1.8
Wearing brake pads on a 1996 Buick Centry
Stop going to Auto Zone !!!
I have never had one brake issue in 49 years,
of doing my own work
So the answer is-- you have not found a shop or
mechanic, that knows how to work on or diagnose
a brake issues & the best part is- brakes are fairly
easy, no matter what has to be done
I would guess that either side rubber flex brake hose
is restricted & should have been replaced for safety reasons,
when the car was about 12 years old
Add to that- calipers that are rusted inside
Then- never changing brake fluid every 2 years,
more rust inside EVERYTHING
Add-- never removing rust from anything that moves
or slides & never lube anything- because that is what
you get when you pay for brake service
Sep 05, 2013 | Cars & Trucks
New brakes squeaking
Poor quality brake pads or improper machining of the brake rotors is the common cause. Use factory OEM disk pads from the dealer, not the cheapest thing out there to avoid this type of problem with noise. Note the noise doesn't affect braking...
Jul 12, 2012 | 2003 Ford Taurus
1996 chrysler Lhs air conditioner started blowing hot air
You've probably had it fixed by now, but I doubt it is low on freon.
Unless something happened to cause a leak that quick.
My first guess would be a relay or power problem with the ac clutch on the compressor.
Most mechanics can work on brakes and ac, but some brake shops don't have the equipment to work on ac.
Jul 10, 2012 | 1996 Chrysler LHS
Where the brake lines run under my truck
We get a few of these questions
You have to step back & see it from our perspective
You say you have fluid under the truck
Is it brake fluid?
If so,wouldn't you get under it with a light
& see where it is coming from vs: going to the internet?
You don't assume anything,you inspect,look it over,
then ask a question
If you can change calipesr,rotors,pads,etc,you can find a leak
There are no diagrams for brake tubing
You replace what is there,anyway you see fit
That is a self learned skill, to fabricate brake tubing
& a job repair shops don't want or do well
There is no ready made lines,only straight tubing at
parts store & fittings
May 24, 2012 | 1999 GMC Sierra
I had my rear brakes and rotors replaced at a local shop 2 1/2 months ago. Two weeks ago my rear passenger side tire started to smell like burnt rubber. I brought it to the dealer for a oil change and had...
The shop that did your brakes should repair/replace the caliper. He HAD to install the pads into the caliper & had to remove the caliper to install new rotor. Hold that shop accountable for the repair. And don't take NO for an answer.
Mar 18, 2011 | 2009 Nissan Armada
Had new hubs, rotors and brake pads installed. I got my car inspected...it failed. Said the brake light is staying on. I did not have this problem before hand or the day after installation. Now it stays on...
there are wires running from wheel brgs to abs unit under the hood its very possible something happened to one of those wires during instalation of brakes
Jan 19, 2011 | 2004 Chevrolet Tahoe
I took my 1989 Dodge Ram into a shop because the diesel fuel was leaking, ended up having to pay for a fuel injector pump. Now three of the four gauges on the dash do not work (fuel, oil pressure and...
If they can't fined anything wrong with the car itself the problem might be in the sensors. IDK what kind they use in that car, but the mechanic might not have the electronic equipment to diagnose, check, or solve the problem. They may have been damaged when they fixed it, might be wear and tear, or they probably just have to be reset/ re-adjusted. Most people don't bother to fix them if that's the case cause they see it as a pointless expense if nothing is wrong with the car it's self. Another issue is replacing them. Most mechanics will opt to replace them cause it's easier and they can charge you more...then again it might be expensive for them to ship it somewhere so some one can actually fix it, and then pay them also. Most mechanics don't know much when it comes to circuitry. In ether case most people don't do anything about it and continue to use there car with all the red flags on. Ether way if it's going to brake down it will anyway and you'll still have to pay to fix it. Usually at that point people usually decide it's time for a newer car anyway and sell, donate, or junk it. If you really want to keep your car though I suggest you or some one you know to just look it over once a month and see if you can see anymore wear and terr. It's a bit obvious sometimes if there's anything physically with it. Also have a mechanic give it a thorough inspection once a year. Good Luck
Sep 15, 2010 | 1989 Dodge Ram D-Series Pickups
Nintendo DS Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
