Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Vaccuum will not ****
Dear Sir;
I have a Bissell Clearview Vacuum and it suddenly will not ****. I had this problem once before and found that the hoses were clogged. That is not the problem now. I checked all the hoses and they are clear. Can you suggest something else for me to try?
  • kloans Sep 07, 2008
    My Bissell Candy Red 12 amp wide cleaner turns on and runs for 2 to 4 minutes and then the sort of turns off. The brush is still spinnning but it the motoer or vacuum suction stops? And when I turn the bruch off witrh the power still on, it stops.
    If I let it sit for an hour or so and turm it back on, it will then run for 2 to 4 minutes and then same as stated above!
    What is wrong and how do I fix it?
    This is my 2nd Bissel and I can not fix it, it will be my last!
    Thanks,
    Kevin M.
  • bonnieupinnh Nov 14, 2008
    I have the same problem. I unscrewed and cleaned out the hose thinking that it was clogged, and would work right after that, but it didn't. it actually got did it again!! How do I fix this?
    President:
  • 1,673 Answers
Remove the hose from the holder, if you have suction at the end of your hose, then the problem is down below that point. Check the dirt inlet for a clog. Also the belt may have stretched and isn't turning under load. If you haven't replaced the belt in a while, change it and check the brush roll and make sure the ends are turning freely.
If no suction at the end of the hose and your hose is cleat, then the filters are clogged, check all of them.
Posted on Jun 21, 2008
How to use bissell proheat clearview plus
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 07, 2010 | Bissell 7901-R Clearview Proheat Plus...
Need manual for bissell proheat clearview force rug cleaner
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Aug 21, 2010 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat Clearview is not spraying water nor taking
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
How to replace belt on a bissell proheat clearview plus carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jan 27, 2010 | Bissell 7901-R Clearview Proheat Plus...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
How do you change to belt on the Bissell Proheat Clearview?
heatman101
et
Oct 14, 2009 | Bissell 1699 ProHeat Clear View Upright...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
