Gateway 510XL won't boot up
Hi - I just received a Gateway 510XL tower s/n1098504400. When I try to boot it up, the hd led comes on for a short time but there is a flashing red led on the motherboard - I let it flash for over 50 times (no pauses) before powering it off. It will repeat the scenario each time I try to power it on. The power supply 5V and 12V check OK with a digital meter. CPU and power supply fans are running. I tried a different set of RAM and no change. It has a SATA hd and I don't have another PC to check the drive in.
  • 6,487 Answers
If the PC wont even show the POST and there's no way you can get in the BISO setup, better try resetting the BIOS of that tower you can find the the steps how to manually do it on the manual its called "jumper settings" to bring the BIOS to its default settings because sometimes incorrect settinsg on BIOS can be a cause of that.
Hope that helps.........
Posted on Jun 21, 2008
  • 114 Answers
If something pops up on the monitor, it's probably a drive problem, maybe there is no O/S, if nothing pops up on the monitor, there is a BIOS error or another hardware error.
    Genius:
  • 1,142 Answers
Do a flea power
  • Maanita Chadha
    Maanita Chadha Jun 21, 2008
    Is the computer working or not give some more details of the problem you are facing, so that the correct solution can be provided.
    regards
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Gateway GM5472 won't boot no power
No power and won't boot suggest a power supply problem in the tower--it is listed as a desktop unit.
What is common on a lot of units (computer towers, TV sets, you name it) is the stand by power supply which is on 7/24 fails.
The most common reason is filter caps dry out because cheap ones and ones rated too low a voltage are used.
The beauty of this is if the power supply is removed and opened you will be able to SEE the bad ones.
I will attach a photo of bad caps--tops which should be perfectly flat are puffed up from a little to a lot and or brown material is seen at top and bottom of the cap.
I have fixed many towers (desktop units) and other equipment with this problem---most of them at first had to be turned on a few times to get them to come on--it gradually gets worse until it will not make it on.
If bad caps are found you can usually buy a replacement supply at a reasonable price or replace the puffed up caps (seen as many as 8 bad in one computer tower).
This answer is based on the information you provided in your question and the answer from personal experience.
SD TECH
4_25_2012_5_11_26_pm.jpg the two larger ones are bad for sure.
Apr 25, 2012 | Gateway GT5220 PC Desktop
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
Got a Intel E210882 Motherboard for a gateway 510XL computer. The computer comes on then shuts off. It does this at random intervals. There is a red LED light (CR9E1) that comes on at the bottom of the...
Hi Scott,
It seems that you know something about computer (Good Job!) , have you tried to isolate it with other computer parts? I mean if you have some spares.
If you dont mind may I ask the specs of your Processor...etc..
Sometimes the compatibility of each part can be the cause of this problem.
Thanks.
Mar 16, 2011 | Intel PGA478 Motherboard
When upgrading the memory of this PC, what is the
Set your computer to optimal configuration. To do this is to access the bios by keep pressing the delete key in the keyboard while you start your computer. Save changes and then restart.
Oct 26, 2009 | Gateway 510XL (2800446) PC Desktop
System will not boot up
Hi there
Hit F2 on boot up and go into the Bios settings, look for the boot order and change it to HDD as first boot device, hit F10 and save and exit.
The PC will restart and should boot into the hard drive.
Good luck
Jan 26, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Tower intermittently loses power
i think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Dec 10, 2008 | Computers & Internet
My new WD SATA hard drive does not have a 4-pin connector
Hi nas2,
You can purchas a SATA power cord addapter that can assist you. The cord is called SATA Serial ATA Power Cable. Unfortunetly, Best Buy™ does not carry these cables. You can however google the cord and order it online for cheap.
Sincerely,
Agent Xiong
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
