Question about Samsung Televison & Video
TV screen went black
TV went black in middle of show. Could not bring back. Eventually, all 3 lights were blinking in front indicating lamp need replacement, which I did. Still having same problem. TV is 3 years old. In past, when turned on, screen would be a pinkish color and I would have to change the source and it would go to normal color. What more can I do?
  • 1 more comment
  • mikie1 Jun 21, 2008
    How long is a picture tube supposed to last? Surely more than 3 years. Could it be anything else?
    What is a light or dip engine? I read that can go out with the lamp or on its own. Would it cause this screen problem?
    I still am not sure what the problem is. There were several anwsers and all different. I will take it to a repair person. Thanks.
  • 2,071 Answers
It seems your problem is in horizontal section,the horizontal output transistor is defected already,the horizontal produce high voltage,if this voltage is gone the picture is gone but power is there because light is there,,you better checked this or find a technician repair this problem to avoid high voltage shock ..this is not cost too much ,,only a transistor and little reheating on that section.....
Posted on Jun 21, 2008
  • 1,512 Answers
Hi
It wont be a picture tube failing. Thats not been a problem in sets for 30 years. Just an urban myth that when the picture stops, the tube has gone!! dont heed that advice :) It is more likely to be a power supply fault, or something failed in a linear stage like the vertical or horizontal circuit. These sorts of repairs should really be done by a qualified service tech. There are dangerous voltages in the back of a TV, that without proper training, you may hurt, or worse kill yourself if you get into attempting a repair.I suggest getting a quote for repairs, and if the repairs cost is more than half the replacement cost, then go for there placement set.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
  • 4,472 Answers
There are more problems posted with samsungs then any other television at least that I have seen. It sounds like it will need to be serviced. It depends on your expertise. If you know enough about electronics and circuit boards then maybe. I would not recommend it but it is possible and I could find you the service manual.
Keep me posted,
Lee
Posted on Jun 20, 2008
  • Lee A.
    Lee A. Jun 20, 2008
    You can also have the closest authorized repair center service it as well.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    This is not a tube tv. This is a projection tv it a much newer technology. These samsungs regularly go out between 2-3 years. I recommend Hitachi as they are the best, then sony, and panasonic. I can assist you further if you need anything.
    Thanks,
    Lee
  • Samsung Master
  • 6,487 Answers
I think the picture tube should be replace for this unit base from what you have said, so better bring this unit to a reapir center near you and let a professionale check it for your safety also.
Hope that helps...............
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
No picture on tv all three lights flashing on front of tv.
Three blinking LEDs mean lamp may be defective replace the lamp.
May 25, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
