Question about Samsung TXN2771HF 27" TV
TXN2771HF (5yr old) - Front Panel a/o Remote Issue
Remote control will Not turn TV ON, but once TV is Manually turned on, the
remote will operate ALL unit functions..also, randomly, when tv is manually
turned on, the volume(s) and channel(s) settings will cycle from lowest to
highest until manual intervention on the front panels causes condition to
cease..
  • 20 Answers
Sounds like the 5 volt supply is low, Look for the 5 volt regulator, Measure you can go directly to the sensor 3 pins 1 will be 0 volts one will have 5 volts the other is usually a fluctuating 3-5 volts if 1 pin has to have 5 volts if it is low check capacitors around the 5 volt regulator probably 47uf to 100uf look for rusty look on the leads. If you see it change it! check these voltages with set turned off ( standby ) do not attempt if you dont know what your doing. Good luck. The reason it works when it is on is because there is a run 5 volt supplement.
Posted on Jun 21, 2008
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
My 2 year old tv has just started to go wild. Just put it on today and where u select the source on the menu option, this keeps scrolling through.. no responce from the remote and when switched off at the...
Hello mrdavidmetca,
Welcome, and thank you for using FixYa!
I would start by pulling the batteries from the remote control. Manually turn the TV off and then back on, manually. If the issue resolves, replace the remote.
If the issue continues; you will need to find a local TV Repair Shop and have the Tuner Board replaced.
Have a great day!
Sep 09, 2011 | Televison & Video
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG LCD '42LG6' TV Remote control seems to be jammed - the TV button on the remote is lit up and won't turn off - now I can't seem to do anything - The actual TV can be turned on and off and we can change...
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
Mar 03, 2011 | LG 42LC2D 42 in. LCD HDTV
FRONT POWER LIGHT AND DVD SIDE LIGHT ARE BOTH ON BUT I CANNOT TURN ON THE TV NOR OPERATE THE DVD. I HAVE PLUGGED OUT THE TV FOR THE DAY AND THERE HAS BEEN NO CHANGE.
I'm not sure if you've already tried replacing the battery of the remote control which is usually the common issue. But if you have, and it's still not turning on, try manually turning on the power directly from the TV by clicking on the up/down Channel. Because it is highly unusual if you cannot turn on both the TV and the DVD. So it is mostly likely a remote control issue. You can also try using another remote control of the same brand to see if it would work. Hope this helps.
Oct 22, 2010 | Televison & Video
I cant to program my cable channels with my univ remot sony tv
do it manually, front panel controls, or buy sony brand universal at wallymart
Jan 01, 2010 | RCA Universal Remote Control
Cant get the remote to turn tv on off or channels
hmmm.. Do you have another remote that will operate that tv, try that remote and see if it will turn on and off the tv. IF you bought this new remote because your old one quit working it may be the tv and not the remote. If you have a camera phone you can check your old remote. Turn on your camera and aim the remote at your phone, look at the picture on the phone and press the power button on the remote, you shuld see the front of the remote flash, if you do then it is the tv causing your issue.
Sep 02, 2009 | Philips Magnavox 20MT133S 20" TV
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Samsung TXN2771HF 27" TV Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
