Question about Gateway FPD1960 19" Flat Panel LCD Monitor
How do you take the back off of this monitor?
I've removed all the screws and the base, but I can't get the back off.
I just had to use a screwdriver and go all the way around the edges. There were very strong clips - almost like it was glued, but it wasn't.
Posted on Jun 25, 2008
The backs are usually clipped on to the monitor aswell as been screwed on , to pry it apart you have to use a flat head screwdriver , go round the perimeter of the cover and pry it gently away .. but be careful as this leave stress marks on the sides.
Posted on Jun 21, 2008
How do you take the base stand off of an envision 22in lcd tv? I want to mount it to the wall?
There is a screw on the part of the base where it connects to the monitor back, it is located on the pivoting arm, remove or take loose this screw and lift the base by holding the side opposite the screw. the base should lift off with at very most just a bit of wiggling. You can now use the wall mounting screw holes located under the corners of the sticker on the rear of the monitor, they are usually covered with a perforated area.
Jan 16, 2011 | Envision H22W 22" Monitor
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
How do I open it to look inside?
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
Nov 18, 2009 | X2Gen MG19MY 19" LCD Monitor
How do I remove the back from my acer al 1916W
face down the monitor over a soft surface to avoid scratches .Remove all screws that you can see.There are more screws that mount the leg to the monitor .Those are hidden you can not see.Covered by a little plastic cover shell.After you remove all the screws ,now you need to remove the back cover from the monitor .using a flat screw driver or another slim tool begin from one side .stick the screw driver into join line between the front and back cover and twist it gently.this is hard part of the operation.You got to be careful .try to loose one side first then other sides ll be easier.
Apr 06, 2009 | Acer AL1916W 19" LCD Monitor
Remove base completely from envision monitor
after removing all the screws, i used a knife to remove the plastic casing surrounding the monitor. that exposed four screws that when removed, released the base from the monitor. it was just a matter of putting the casing back together. thanks
Jan 30, 2009 | Envision 19" Widescreen Flat Panel LCD...
Remove base of envision lcd monitor G19LWk
The base of the G19LWK can be removed but it takes a little work. You have to remove the black plastic case that sandwich the LCD screen. First remove all the screws on the backside of the monitor. Then, at the seam of the two casement halves, GENTLY pry the front screen frame away from the display. Work carefully all around the edge of the display to separate it a little at a time and the pull it away in one piece. Next you will find that the back casement is held to the display with plastic tabs around the perimeter. Carefully pry the tabs away from the display frame to separate and remove the back casement. Now the base mounting is exposed on the backside and held with 4 screws. Remove the screws and the base will come free. Re-assemble the casement by snapping the back on first followed by re-installing the screws. Then snap the front frame by lining of the plastic tabs and pressing the frame down evenly around the display. You are done!
Jan 30, 2009 | Envision G19LWK Monitor
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
Dec 21, 2008 | Hyundai Computers & Internet
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Aug 26, 2008 | Philips 190B6CB/27 19" LCD
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
