Question about Archos 605 WiFi Digital Media Player
404 dvr station remote not working
Buy a new battery
Posted on Nov 04, 2008
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
Aug 18, 2010 | Archos DVR Station MP3 Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Security First SDVS-1904 Setup (Not D-Link) Needing help with this. We installed the 4 cameras and the DVR. They're working fine. Now I'm trying to get it to come up on the computer so we can see the...
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Mar 04, 2009 | D-Link Securicam Network DCS-950G Wireless...
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Archos dvr station remote control
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
Nov 30, 2007 | DISH Network ViP622 DVR DTV Receiver /...
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Connect My Archos to my TV
Archos has a site with a video demo on how to connect all leads
Mar 21, 2007 | Archos AV 500 400-Hours Video Recorder
Archos 605 WiFi Digital Media Player Logo
49 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
