Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Where to buy a new oil filter and fuel filter?
    Scholar:
  • 80 Answers
You can buy a new oil filter and fuel filter at the briggs & stratton website here are the exact links
oil filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={803C6266-A7A3-4F83-A56E-8148DE31F0F6}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
fuel filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={7135A082-B7B4-4F72-B4AF-29FBEBB661C5}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
Regards obliqueridge
Posted on Nov 19, 2010
SOURCE:
207cc 1.6 Gt Fuel Filter location
What do want to change the fuel filter for they never need changing here in europe as the fuel delivery pumps in the fuel stations have micronic filters inside the pumps ,europeon law so it shouldnt need changing unless it corrodes away that is if its a metal casing .Their is a gauze filter on the fuel pump inside the tank but if this motror runs ok leave well alone and stop playing around trying to a boy racer sunday mechanic job ,change the oil every 5/6000 miles with a oil filter every third oil change and use the cheapest diesel/petrol engine oil you buy ,gap the plugs every other oil change and it will run like a dream ,stick to putting a boom boom box in and stick go faster stripe and leave it alone
Nov 29, 2013 | 2008 Peugeot 207 CC
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
Civic EX 1997 D16Y8 fuel economy problem (waisting fuel)
The most typical thing to go out that will waste fuel is O2 sensors. They can be marginal where they will not throw a code but will not be efficent. You can test the operation with a good scan tool or just buy two new ones. Also buy a can of "Seafoam" and dump it in your tank next fill up
Nov 01, 2012 | 1997 Honda Civic
What do i need to buy for a tune up on my 2000 hyundai elantra
- Spark Plugs (make sure they are gaped properly)
- Spark Plug Wires
- Coil Packs (if needed) or Distributor Cap & Rotor (which ever so equipped)
- Air Filter
- Fuel Filter
- Oil
- Oil Filter
- Transmission Filter (optional)
- Transmission Fluid (optional if you do change the trans filter you will need the fluid)
- PCV Valve (optional)
- Bottle Of Fuel Injector Cleaner (add to fuel tank kind)
Jan 17, 2011 | 2001 Hyundai Elantra
2002 yukon hard to start, where is the fuel filter and how to replace it.
FIRST RELIEF FUEL PRESSURE BY REMOVING GAS CAP REMOVE FUEL PUMP RELAY START ENGINE UNTIL IT DIES LACK OF FUEL. FUEL FILTER IS MOUNTED TO THE RIGHT FRAME RAIL.NEAR THE FUEL TANK.YOU NEED A FLARE NUT WRENCH TO LOOSEN FUEL LINE AT FILTER AND A ADJUSTABLE WRENCH HOLD FILTER LARGE NUT WHILE LOOSEN FUEL LINE THIS KEEP FROM TWISTING FUEL LINES WHILE LOOSEN FUEL LINE.BESURE TO GO TO DEALERSHIP AND BUY NEW O - RINGS AT FUEL FILTER LINES.LUBRICATE NEW O- RINGS WITH CLEAN ENGINE OIL.WHEN INSTALLING NEW FUEL FILTER DONT OVER TIGHTEN FUEL LINES CUTTINGTHE O -RINGS AT FUEL FILTER.IF SO THEY WILL LEAK GAS WHEN YOU START UP ENGINE.WHEN DONE CHECK FOR GAS LEAKS WHEN DONE DONT DRIVE UNTIL YOU CHECK FOR LEAKS FIRST.
Aug 16, 2010 | 2002 GMC Yukon XL
Oil gushes out of air filter hole.
Oil normally comes out of the air filter area a little bit, but over time, once the oil rings start to wear, more and more oil comes out. So you can either have new oil rings replaced, or you can put in a crank ventillation valve in there and it often helps slow down the oil from entering
May 18, 2010 | Honda Hmantis Mantis Garden Tiller with...
Fuel filter
There is no need to change it frequently. If there is a loss of engine power or if throttle cuts out then may be its the time to change fuel filter. It is recommended by peugeot to change fuel filter (but depends on fuel purity) after every 36000 miles.
You can clean it yourself
Dipp the whole filter body in carosine oil tank and leave it in there for about 20-30 minutes
Pour some petrol in filter with the help of plastic piped and apply a slight air pressure (use a piece of pipe to blow) in the reverse direction (marked with arrows) of fuel supply to clear residue and heavy oil composite that clogged in filter.
Repeating the cleaning process 2-3 times will clean the filter to reuse it without the need of a new one to buy.
Jan 06, 2010 | 2005 Peugeot 405
Camry 1991- really sluggish and jerky
It's just going to take some time and simple cleaning. If there is an Auto Zone around your area, you can buy all the things needed to get the car running 100% again in no time at all for under $40.00. Here is a few things that I do when i get a new car with a few years under it's wheels. Buy a bottle of injector cleaner for the fuel injectors, like STP, a bottle of Marvel Mystery Oil to add to the engine oil, and two can's of Throttle body cleaner for the throttle body and follow the instructions on the can. Make sure it's throttle body cleaner. The Carburetor cleaner is to corrosive for the throttle body gasket. Once you have reached 3,000 miles, service the engine and have them replace the oil (5W-30) and filter and add another Marvel Mystery Oil. This will clean out all the carbon and sludge in the engine to free up the oil passage ways, replace the Air filter, and PVC valve every 30,000 miles or once a year. Cleaning out the throttle body and adding the fuel injector cleaner will also help the fuel system and have them replace the fuel filter every 30,000 miles or once a year to ensure there is no fuel restrictions in the fuel system. Once this has been done you will notice the engine runs like new and you may have to use the Marvel Mystery Oil and fuel injector cleaner every 6 months to keep the internal engine free from sludge and carbon. Good luck and keep me posted, be glad to help you keep the car running 100% for a long time.
Sep 05, 2009 | 1991 Toyota Camry
1999 volvo v70 oil change questions
You can buy a canister wrench at the local auto parts store. You do not need to torque the oil filter on, just hand tighten, No new gasket for the drain plugs just do make sure that it is tightened properly
Feb 10, 2009 | 1999 Volvo V70
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
272 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
