Question about Nikon D40x Digital Camera
Images missing from memory card
I shot approximately 40 pictures and viewed them in the camera. When I tried to download them, they were gone!  Nor could I find them in the camera when I tried to see/find them there.
  • 21 more comments
  • Marge Rudman Jun 21, 2008
    The response gave me a link which I thought would take me to data recovery soft ware download. Instead of that, I got stuff about Vista which I want nothing to do with. I'm on a Mac. If you mean by using a computer to check that the picture really isn't there - attempting to download the pictures, Yes I did that.
    Marge
    The Nikon apparently has no separate internal memory. The 2 gig memory card has 200 fine images from earlier in the week. It is only the approximately 50 images from today that are missing. The 2 gig card should hold about 350 fine images. The nearly new battery was freshly charged. The camera behaved perfectly normally. I viewed the images after I took them, so I know they were in there at one point.
    File Scavenger doesn't seem to be compatible with Mac. I tried downloading it to a memory writer - no luck there either
    The pictures were jpg, not RAW. I removed the memory card from the camera inserted it in the card reader then into the USB port. With that, iPhoto opened, as always and began its downloading process. As always, i selected "do not import duplicates" of which there were plenty. This is the same procedure I've used successfully all along. I have the OSX.5 operating system It does download RAW, as NEF. But, that wasn't an issue here.
    Thanks for all of the suggestion. I'm reluctant to purchase $145 software on line without knowing whether it will work. I may wander into the Apple store, purchase the software and attempt the retrieval there with the help of a "Genius". The photos in question don't justify the expense. But, getting to the bottom of this and having the hardware for future fiascos could.
    So, in the meantime, I've marked and retired the memory chip in question and may never use it again.
    Thanks again,
    when the response to this come, I'll probably decide to end the exchange, declare myself "satisfied" even though it's not solved and pay up.
    Marge
    File juicer downloaded successfully. But, it "found" only the images which had never been lost. I reinserted the memory card into the camera and deleted those visible images one by one. I DID NOT format the memory card. Then I ran the memory card through filejuicer again. It found no images to recover.
    The plot thickens.
    That makes sense and is worth checking out. However, IF the blankity-blank thing is that damaged, I don't think I want to use it at all.
    o.k. we've come full circle, I think. I will keep the corrupted card in case I decide to invest in the $145 recovery software sometime. Hopefully I won't have occassion for it. In any event, I've learned some stuff and know better than to trust the card ever again. In the old days, rolls of film got damaged or lost in processing. Now, memory cards corrupt.
    It's just not a perfect world.
    thanks,
    Marge
  • Marge Rudman Jun 22, 2008
    NOTHING HAS WORKED.
    TOO BAD.
    MARGE
    apparently not for Macs.
    with a different memory card, the camera is functioning perfectly.
    I download to my Mac via a memory writer having been taught it's best to avoid directly connecting your camera to a computer.
    How do I reach dilipbagdi to let him know?
    Does CardRecovery work with a Mac?
    How much does it cost?
    I'm on a Mac
    didn't find anything compatible
    I quit.
    Problem NOT solved.
    Marge
    In the context of all of the previous communication, this comment doesn't make sense to me.
    Marge
    Looks like there's no solution this time.
    Thanks, guys (and gals?)
    I regularly format my memory cards. True it hadn't been formatted before the last shoot as I had other pics on there. This has been a first time problem.
    That card is not to be trusted and is permanently retired
    Nothing suggested had led to recovery of the missing images. Perhaps there is no solution this time. Perhaps some expensive software from Apple (for my Mac) would do the trick. I've learned a few things and you all have spent a lot of time with this problem. I've kept some of the suggested links for future reference. Even though the problem was not solved, I'll pay up because it doesn't feel right otherwise.
    Thanks anyway,
    Marge
    Thanks anyway,
    Marge
    This suggestion reveals that you haven't read the previous measures and comments from me
    NO WAY.
    You clearly didn't read the earlier discussion
    NO WAY.
    Please see previous comments.
    You can stop sending me emails.
    thanks.
    Marge
    no it's not solved. Tomorrow I will go the the camera store that sold me the Nikon and see if they have retrieval software there that can help me. I think we have gone as far as we can this time around. thank you and I have already indicated that I will pay for this even though we haven't truly solved it, I've learned some stuff.
    Marge
    Sergeant:
  • 458 Answers
Is this solved or not? You rated a few people, but I do not see a fixya yet. If you need more help from one person, you can click on their name. Then you can ask them directly. After you do that you can always come back here and rate the person that solved your problem.
Posted on Jun 22, 2008
  • 91 Answers
What Probably happened was that you format or delete all the photos from your Memory card.
Thank You!!!
    Scholar:
  • 198 Answers
Take off the memory card n start the camera, it may be stored in ur cameras internal memory....
or else try recovering back those fotos frm ur card, usin recovery softwares..
try putting ur memory card into a card reader and chk for the fotos by connecting it to a computer...
these r the different chances u can try...
thank u
    Guru:
  • 1,894 Answers
Seeing all the other solutions i can give u only one line answer
forget those photos. its ur hardware fault.
u cant retrieve it i think.
also i would suggest u one thing.
please do a format of the card in the camera before starting to use the card in the camera.
this can prevent problems like this.
  • Nikon Master
  • 19,396 Answers
The D40X has internal memory.
Remove the card and start the camera with no card, go to picture viewer and check if you can view the pictures.
  • 2 more comments
  • Ginko
    Ginko Jun 22, 2008
    Start the camera with no card inside and go to view pictures, see if you can display the lost pictures
  • Ginko
    Ginko Jun 22, 2008
    Card recovery does not work on Mac, here is Stellar Phoenix Photo Recovery - MAC Photo Recovery Software 1.0
    Try what suggested above first.
  • Ginko
    Ginko Jun 22, 2008
    Did you remove the card and start the camera as suggested?
  • Ginko
    Ginko Jun 23, 2008
    If you formatted the card you cannot recover anything from the card.
    Genius:
  • 1,847 Answers
Hello margerudman,
you can try these steps which i think is already been mentioned and is nothing more to it. i have been seeing this post since yesterday.
1. Chk is it store in the removable memoryand an cameras internal memory.
if not
2. Chk the memory properties for used space, if it shows there is used space then download this file and try recovering the pic >http://www.data-recovery-digital-camera.com/downloads/digital-camera-data-recovery-demo.exe
3. if it shows all free space we cant do noting about it.
thanks
Kevin.
    Genius:
  • 1,665 Answers
They probably accidentaly have not been saved.
    Sergeant:
    Champion:
  • 347 Answers
Hello Marge,
Marge, if you follow this link,
http://www.p-dd.mobi/
It will take you to a website where you will be able to download a software called "Memory Card Data Recovery Software"
Download it, run it, and then it will be able to fix + find your lost pictures.
Since you are telling me your memory stick is "corrupted" i dont know what files did you erase, but if the program isnt able to solve your issue, let me know and i will further help you.
Good luck,
Dahaka
    President:
  • 1,257 Answers
CardRecovery is a photo recovery software for digital memory card used by digital camera. It can effectively recover lost/deleted/corrupted photos from various memory cards. It supports most memory card types including SmartMedia, CompactFlash CF, Secure Digital Card SD, Memory Stick, MicroDrive, xD Picture Card, Multimedia Card MMC and more.
let me know if you want this software for recovery.
  • 1 more comment
  • Deeps . Jun 22, 2008
    Hello ,why don't you want card recovery for mac,it may cost you very much ,but the software i will give you will not cost you anything..i will just give you the download link for it.but if still you want download for mac let me know.................
    thanks
    Try this software and let me know.
    http://for-mac.com/photo-recovery.zip
    if you still need help let me know.we will resolve it
  • Deeps . Jun 23, 2008
    you don't have to pay anything for card recovery software ,its full version and its free to use.that's why i told you to use it with windows..........mac software charges for recovery software are too much so i thought not to spend your money for recovery........
    thanks
    dilipbagdi - technical associate
  • 2,071 Answers
It seem you better to reset your camera setting in order to read files your camera is already functioning abnormaly ,,just go menu setting and default the factory setting..and its function normaly again..
  • 197 Answers
Well..this is certainly a popular issue, is it not?
how about this.
go to pack.google.com
get picasa(great free image management s/w)
hook up your camera to your mac
**** the images out
if it's not there with picasa, they aren't there.
Posted on Jun 21, 2008
    President:
  • 2,712 Answers
Try deleting all pics on the card after taking a backup first. Now try to click as many pics as possible and see if you can get up to the 350 range. If you still get stuck at the 200 pic range, then it could be one of two things:
1. Either the memory card is faulty and doesnt actually hold 2gigs, or
2. The file size of the pics are large and actually using up the 2gigs!
    Master:
  • 638 Answers
You may have possibly partially transferred images to the computer - are they anywhere to be found?
You may have whilst taking images altered the resolution setting thus reducing the capacity of the card.
Download this and run the memory card through it it will pull up any missing images.
www.pcinspector.com
or
www.konvar.com
downd load the program, install it and direct it to the plugged in camera in the download mode.
Also get hold of a card reader, saves on batteries and this sort of problem
hint: it's always best to reformat cards IN the camera). Check your software preferences. And it very well could be your memory card is wonky. Have you tried other cards and had the same problem?
there is a software with authorized service centre that helps you get your lost images back,but they charge you for that.and also give you the software so if you get this problem again you can yourself solve it again.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 6 more comments
  • hemant somaiya
    hemant somaiya Jun 21, 2008
    any updates.
  • hemant somaiya
    www.pcinspector.com
    or
    www.konvar.com
  • hemant somaiya
    any updates plse let me know
  • hemant somaiya
    hemant somaiya Jun 22, 2008
    updates
  • hemant somaiya
    any updates
  • hemant somaiya
    tell me where have you reached till now
  • hemant somaiya
    clarify plse
  • hemant somaiya
    updates?
    Genius:
  • 1,036 Answers
It is possible that the memory card has a bad sector in there, and therefore cannot store the data in that spot.
After doing what you can to recover the good photo's, delete the ones you are sure you have copies of, and the missing ones may appear, or more likely, not.
To test this theory, take the similar quantity of photo's again, and see if the problem repeats.
If it does, you know you have a lower limit on this memory card, or would be better to purchase a new card.
    Genius:
  • 2,028 Answers
I had a recent problem with my camera doing the same. I had about 100 pics on the 1g memory card, took 20 or 30 more, viewed them, turned the camera off, then when I went to download them they didn't show up. Turned out to be that the memory card failed. It will now hold about 70 pics, then nothing. I bought a new card and it works fine. To see if this is the problem, take off about 50 pics and then just start shooting, see if will take you up to around 200 (the amount you said were there) then see if it will hold any more.
  • Ryan Rogers
    Ryan Rogers Jun 21, 2008
    Memory cards are still way above rolls of film. Think of how many rolls you lost or damaged, because that number will be at least 10 times that of how many memory cards you have to replace in you lifetime.
  • Ryan Rogers
    Ryan Rogers Jun 22, 2008
    I forgot to mention that, when this happened to me, I could not recover the mising images, the bad sector in the memory card made them unrecoerable. I'm not using Mac, but the recovery software I used got close, but not enough to keep the pics. I'm glad your camera is woking properly, but I'm sorry that you're going to lose your pics.
    Sniper:
  • 114 Answers
    Brigadier General:
  • 6,966 Answers
Two possible ways to check/recover:
1. Try Macintosh Data Recovery Software;
2. Use a memory card reader attached to a Windows PC and try all the suggested file recovery utilities.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,447 Answers
Hi-
When you took the pictures what are the formats of the pics? are they RAW? Have you tried using an adapter on or card reader to manually transfer the photo to your mac? or did you hook camera directly to your mac? are you using a special application or program when your transferring the photos to your mac? pls keep me posted so that we can solve this. Thanks!!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 21, 2008
    i understand just checking actually since im assuming that there could be a glitch importing photos after you upgraded your system in which that is the next question i want to ask- are you using 10.5.3 OS? have you tried shooting and saving it to a different memory card and transfer it to you mac? did you get the same issue by any chance..? i appreciate your time on this. thanks for the info
  • 13,433 Answers
Hello
you can attempt to scan the memory card for recoverable images with http://www.quetek.com/prod02.htm File Scavenger, I use this tool in recovering pictures from corrupt memory cards, try the trial it should be able to find your pictures if recoverable or on the card at all.
the trial doesn't allow you to restore anything.
  • 10 more comments
  • Ekse Jun 21, 2008
    have you tryed the demo does it find the pictures?
  • Ekse Jun 21, 2008
    You never said you had a mac, mate.
  • Ekse Jun 21, 2008
  • Ekse Jun 22, 2008
    Just take the card to a data recovery professional or a camera shop to get in touch with a service guy who can recover them for you.
  • Ekse Jun 22, 2008
    Im posting this again just to make sure it come thought, with this new system you never know.
  • Ekse Jun 22, 2008
  • Ekse Jun 22, 2008
  • Ekse Jun 22, 2008
  • Ekse Jun 22, 2008
    You don't seem to be geting any of my comments.
    Good bye,
    Ekse
  • Ekse Jun 22, 2008
    Just take the card to a data recovery professional or a camera shop to get in touch with a service guy who can recover them for you.!!!!!!!!!!!
  • Ekse Jun 22, 2008
    You do not see my comments?
  • Ekse Jun 22, 2008
    Ok, did you finaly receave my comments? :-)
    Please take a moment to select the solution you are going to pay for. by pressing the accept button.
    Sergeant:
  • 260 Answers
Hello margerudman,
thanks for visiting our site today.
Many cameras have a removable disk and an internal memory. Sometimes you have to select which type of memory you wish to download the pictures from. Please make sure that you check both the internal memory and the removable disk memory as well.
Also, please make sure your batteries are well charged and your memory card is not full. I hope this helps.
Good luck :)
Posted on Jun 20, 2008
  • Ken Jones
    Ken Jones Jun 21, 2008
    It sounds like you have tried about everything. You have lost 50 pictures that seemed pretty important to you. Obviously you do not want to pay for an expensive program to get them back. I know you have decided that the memory card is bad. May I suggest one more thing. Take some more pics on that memory card around the house. These will be unimportant pictures, similar to using up the last couple of photos in a roll of film. Then check to see if you can download those pictures onto your mac. If you can, then your card may not be the problem.. If you still cannot transfer the pics but another card does work, then you know it is the card that is faulty. I am sorry for your frustration. good luck :)
  • 6,487 Answers
Seems it accidentally deleted or somewhat, by the way did you try checking the content of the camera using a computer to check if that picture is really not present on the camera's memory if its reallt not there, better try looking for a data recovery software on the internet that will help you recover any picture that was acccidentally deleted.
hope that helps.........
  • Mark Gil
    Mark Gil Jun 21, 2008
    You can check this link for the data recovery software I've been using that for my self...
    http://www.data-recovery-digital-camera....
  • Mark Gil
    Mark Gil Jun 22, 2008
    You can really buy a data recovery software that will work with MAC but I believe some digital photot store offers a service to recover the missing data if you can check if there's any shop near you I think that will be much cheaper than buying the expensive data recovery software and there's no assurance that it will recover your missing data...
I have a problem with images on a memory card that don't download on to Lightroom, or are not visible after the import has ended. see more detail below. please help.
Instead of downloading the pictures using Lightroom, make a file on your desktop. Copy and paste all of your photos from the memory card into the folder. Open the folder and change your computer's Finder (Mac) or Explorer (PC) to the thumbnail viewing mode. If all of the files show up there, try opening them from there. If not, let me know and we will proceed to step 2.
Jan 02, 2017 | Cameras
Image database error
The manual on page 126 says:
Image Database File error Cannot recover Import all of the images to the computer with "PMB", and format the memory card or the internal memory (page 97). To view the images again with the camera, export the imported images to the camera with "PMB".
If you used the card before in the same camera, it should be compatible. If you can't save the pictures normally, us an external card reader, to save or recover and save the pictures first. Then do a format in the card reader (FAT or FAT32) and when you reinsert the card in the camera, again format the card, this time in the camera. (You always should format in the camera, the first time you use a memory card in a camera, or after you had a failure tithe the memory card.
Mar 09, 2014 | Sony Cyber-Shot DSC-W560 Digital Camera
(1) Full memory card (of Sony Cyber-shot DSC-W300, 13.6MP)plugged through card reader into Laptop, does not open as removable drive. (2) The same card when put back into the Camera, shows all...
If I were in your situation, I would stop trying to download to my computer. I would take the card to my nearest Walmart store and use one of their picture kiosk machines to either print all of the pics or even make a CD copy of them.
Aug 31, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
I lost user manual of my Sony Cybershot DSC-W150
I think you have set the "image storage" to internal. If you take a picture the memory reading should go down one shot-if it doesnt it is because your photos are on the internal memory instead of on auto or memory card. If you take out the card then try to view the pictures hopefully you will now see them. Eventually if this is the problem you will get a notice telling you that "internal memory is now full£.
Jun 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Data loss when trying to copy images to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
"Unidentified Image"
you need some image recovery software that will fix the files that are corrupted
May 29, 2008 | Canon PowerShot S3 IS Digital Camera
Picture viewing problem Sony Cyber-Shot DSC-P100 Digital Camera
Which OS?
Try this link to download updated software. click on download drivers, choose your camera, choose your OS.
Either this or remove your memory card and use a USB multi-card reader or if your laptop has the cardslot instead of docking the camea to the laptop.
Mar 14, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Lost Images
You may have possibly partially transferred images to the computer - are they anywhere to be found? You may have whilst taking images altered the resolution setting thus reducing the capacity of the card. Download this and run the memory card through it it will pull up any missing images. www.pcinspector.com or www.konvar.com downd load the program, install it and direct it to the plugged in camera in the download mode. Also get hold of a card reader, saves on batteries and this sort of problem
Jun 01, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Storable images and file sizes ...
Stylus 300 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2048 x 1536 6, 20 shots 96, 326 shots SQ1 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie All capacity figures are approximate. Stylus 400 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2272 x 1704 5, 16 shots 90, 266 shots SQ1 2048 x 1536 20 shots 326 shots SQ2 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Nikon D40x Digital Camera Logo
447 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
