Question about Uniden Cordless Phone
My cordless says unavailable
I have the Model number 25952 the base handset works but the other one says unavailable what should I do?
  • 1 more comment
  • turnbull Jun 27, 2008
    My cordless says Unavailable
  • Anonymous Jul 01, 2008
    my cordless says unavailable problem,but get no dial tone.
  • Anonymous Dec 24, 2008
    unavailable, no dialtone, will not accept call. Base works fine.
I have a total of three cordless phone including bases.the main phone is charged and ok,the others all say please register. i tried and they all still say the same freaking thing PLEASE REGISTER
GONIN GOING CRAZY
Posted on Nov 04, 2008
I put the phone on the master handset (I registered it)
Posted on Jun 21, 2008
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Handset won't charge
well, it is possible it has a bad cell in the battery, never reaching full voltage. check the battery with a volt meter if possible for 3.6 volts. otherwise trial and error may solve it, but batterys are getting to cost as much as phones nowdays.
Sep 06, 2009 | GE 25952 Cordless Phone
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
Phone beeps & says Unavailable when I press talk to make a call
I have this same system, and could like it if it didn't make people who call sound so far away and hard to hear. I'm thinking of getting rid of them.
But for your problem. The phones in the chargers often "loose contact with the base", for whatever reason it happens. Take them from their charger and place them in the charger for the answering machine main base for about 30 seconds. Then they will "reconnect themselves to the main base". Then put them back to their own chargers and they should be back to their normal use unless their batteries are getting weak.
They can not work without contact to the main base, you have to have the main base plugged in and hooked to the phone line.
Jan 22, 2009 | GE 25952 Cordless Phone
Need instructions to make cordless twin set work
If you had a power failure the memory may have been affected. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may need to register the handset to the base by following the instructions in the user's manual
Sep 12, 2008 | GE 25952 Cordless Phone
HOW DO I REGISTER THE PHONE
I had this problem - just found the solution. The two charging stands aren't the same. One is a base (that plugs into the wall) and the other a charging cradle. I think that each handset needs to be placed in the base to "register" it.
So, here's what I did: place the unregistered handset in the base & both should work.
May 04, 2008 | GE 25952 Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
GE Model 25952 Series 5.9 GHz Handset Speakerphone
take the phone back to the store and get a new one
Mar 03, 2008 | GE 25952EE1 Cordless Phone
Uniden Cordless Phone Logo
486 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
