Question about HP Compaq WF1907 Monitor
Dead pixel I have a black spot on the bottom right corner of the screen..can it be repaired?
  • 85 Answers
Please read the WHOLE of this guide before starting. Software Method
  1. Try running pixel fixing software. Stuck pixels can often be re-energized by rapidly turning them on and off. If this fails, complete the following steps.
Pressure Method
  1. Turn off your computer's monitor.
  2. Get yourself a damp washcloth, so that you don't scratch your screen.
  3. Take a household pen, pencil, screwdriver, or some other sort of instrument with a focused, but relatively dull, point. A very good tool would be a PDA stylus.
  4. Fold the washcloth to make sure you don't accidentally puncture it and scratch the screen.
  5. Apply pressure through the folded washcloth with the instrument to exactly where the stuck pixel is. Try not to put pressure anywhere else, as this may make more stuck pixels.
  6. While applying pressure, turn on your computer and screen.
  7. Remove pressure and the stuck pixel should be gone. This works as the liquid in the liquid crystal has not spread into each little pixel. This liquid is used with the backlight on your monitor, allowing different amounts of light through, which creates the different colors.
Tapping Method
  1. Turn on the computer and LCD screen.
  2. Display a black image, which will show the stuck pixel very clearly against the background. (It is very important that you are showing a black image and not just a blank signal, as you need the backlighting of the LCD to be illuminating the back of the panel).
  3. Find a pen with a rounded end. A Sharpie marker with the cap on should be fine for this.
  4. Use the rounded end of the pen to gently tap where the stuck pixel is - not too hard to start with, just enough to see a quick white glow under the point of contact. If you didn't see a white glow, then you didn't tap hard enough, so use just slightly more pressure this time.
  5. Start tapping gently. Increase the pressure on the taps gradually for 5-10 taps until the pixel rights itself.
  6. Display a white image (an empty text document is good for this) to verify that you haven't accidentally caused more damage than you fixed.
Tips
  • If the pressure and tapping don't work directly on the stuck pixel, start moving outward around the stuck pixel. If you see the pixel flicker while doing this then you know where you can focus the pressure and tapping techniques rather than directly on the pixel.
  • Many people report success with this technique but these instructions won't work in every case. It may take a few attempts to make sure you are pressing exactly on the stuck pixel.
  • These instructions will fix "stuck" pixels, not "dead" ones. Dead pixels appear black while stuck pixels can be one constant color like red, blue or green.
  • An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp (not wet) soft cloth.
  • Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
  • If these instructions don't work, you can hopefully get the monitor replaced through your manufacturer. If your monitor falls under the specifications of replacement, get in contact with the manufacturer to set up replacement plans.
Warnings
  • Do not attempt to open the monitor as it will void the warranty and the manufacturer will not replace it.
  • Make sure you don't get any electrical equipment wet or it may break.
  • Some people claim that touching the screen can cause more pixels to become stuck, although this has not been proven.
  • Be prepared to suffer a complete loss; you may crack the glass when tapping or putting pressure on an LCD assembly.
**Rytech assumes no responsibility if you cause futher damage to your product whilst following this guide. If in doubt, contact authorised service personell**
Posted on Jun 21, 2008
Dead pixel
Posted on Nov 17, 2008
I have a Sony tv model kdl 46s 2010. the picture shows well except bottom right corner and and it is blocking the vision don't know what it is but the rest is fine. What is. Wrong
If the "blocking" of your screen appears to be a random pattern, you have a cluster of dead pixels, and it is best to replace the entire set (as repairs are unreasonably expensive). If you are seeing a black SQUARE at the bottom of the screen, turn off all closed caption and text options.
May 11, 2015 | Sony Televison & Video
Tiny black spot lcd
Erika, Do you mean you have a black spot on the LCD of your camera?
We call that a dead pixel. Can be black and can be white. Most LCD's sooner or later have a one or more dead pixel(s). As long as they are not in the centre of the screen you won't notice them. Even dead pixels on the camera sensor can happen. These you won't see at all, because the software does calculate what that pixel would look like in that specific shot. And the software will place a correct colour on that spot.
Try to live with the dead pixel(s). you won't see them on the actual pictures. Not on the computer to tablet and not on a print.
Dec 30, 2013 | GE Cameras
Grey spots black screen
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
Sep 29, 2013 | Samsung PS-42A450 42" MULTSYSTEM PLASMA TV...
On my toshoba pc 17'' sreen I have black spot on the top corner and the bottom of my screen , is my screen diying oley one year old
There are two types of black spots. The first, I call bruising. This is a dark area on the screen that can vary in size and still allows for proper viewing. The second is a black dot. If it is a black dot about the size of the period in this sentence, it is a dead pixel. Most manufacturers allow for up to 5 dead pixels before they will treat it as a problem. In either case, dead pixels and bruising are more of an annoyance than anything. I have seen screens with both issues work for up to 5 years under these conditions. They will eventually fail but how long it takes it to fail, is anyone's guess. There are numerous outlets for new or used screens. If you plan on keeping this for a while, I would recommend contacting the manufacturer to see if they will do anything or pick up another screen and have it on hand to replace it if it should fail.
Dec 25, 2009 | Belkin Computers & Internet
Black spots on screen in the top corner and bottem of screen
how big are the black spots? are they pixel size? i have one black spot too but its called a "dead pixel" when ya buy laptops these days, sometimes...they will have a dead pixel gaurentee for like 25 dollars, but i didnt choose that so now im stuck with one annoying dead pixel on my 5 thousand dollar laptop but im fine with it i guess. when my screen gets bad, im rich enough to just replace the whole screen anyway. dead pixels cant be fixed i dont think just replaced by the whole screen.
Dec 25, 2009 | Toshiba Computers & Internet
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My LCD TV Has 4 large round black spots (50mm diam) on the left side of the screen. I accidentally splashes a little water on the unit the day before, but in the bottom (right) corner only. It is a Teac...
The dots cannot be rectified, static dots of this kind on an LCD panel are dead pixels or liquid cristal leaks, depending on their hape and aspect.
The only fix is by replacing the LCD panel, that is an expensive part and must be ordered by phone, as it is not normally in stock.
You can inquire by phone here to find out part price.
Mar 28, 2009 | Samsung LN52A650A LCD TV
Black Spots on LCD for Latitude D505
If you?re positive that the black spots aren?t dirt or scratches on the outside of your screen you are probably dealing with dead screen pixels. Short of replacing the LCD screen there is no way to repair them.
Dec 13, 2006 | Dell Latitude D505 Notebook
HP Compaq WF1907 Monitor Logo
661 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
