Question about Acard Technology (ARS-2030LD) DVD±RW Burner
Targer drive not ready.
Well, I happen to have a 1/7 cd/dvd duplicator, and everytime i wish to copy a dvd cd to the other blank dvd's, it states the error, written above. The duplicator is not connected to the computer, it is a stand alone duplicator. I never connected it to the computer. So this is quite the problem i am having. Please post any solutions for me. It will be greatly appreciated.
  • 1 more comment
  • Trevor Edwards Aug 05, 2008
    I have a 1 - 7 duplicator, cds are burning but when I try to burn dvds the error message - source drive is not ready
    can you help
  • Ramon Velasquez
    Ramon Velasquez Jan 11, 2009
    I have a dvd duplicator, and i can burn cd's, but when i try to burn dvd's i get the following message (target drive not ready) what is that, and how can i fix it.
  • Ramon Velasquez
    Ramon Velasquez Jan 17, 2009
    It burns CD's, but not DVD's. I changed the disc, Now I get one drive to work,
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Posted on Oct 05, 2010
  • serwaah_mens Nov 04, 2011
    I tried it and it worked. Thanks
I know I get the same error when I try to copy a cd and I accidentely leave a dvd in one of the target drives. So make sure that when you copy a cd that you have cd-r's in the drive and when you copy dvd's that you have dvd'-r's in the drives. Or it could be something else. Just a thought.
Posted on Jul 25, 2008
The burning drives are not recognizing the blank media.Try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.Try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.Finally clean the drive bays by using compressed air to blow any dust out of the system.
Dec 18, 2013 | ProDuplicator Computers & Internet
To Whom It May Concern:
Usually, to make exact duplicates on this device, you load your master disc (whatever you would like to make copies of) into the top drive, and blank disc(s) into the bottom drive and press the ENT button on the duplicator when the display reads "1. Copy". Hope this helps and if you have any more questions, comments or concerns, please feel free to contact us @ 877-686-8868 for technical support. Thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Feb 13, 2011 | EZ Dupe (EZD3TCDLO) CD-RW Burner
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
I put a dvd in the dvd rom and blank dvds in the other and hit copy and it goes to preparing and the says that the source is not ready.
The "Source Drive Not Ready" error message indicates a problem with your master disc. There is a function on the duplicator called "Prescan" on the duplicator that can check your master disc to make sure it s a "good" disc suitable for duplication.
Hope this helps and if you have any other questions, comments or concerns, please contact us @ 877-686-8868 x208 for technical support.
Oct 14, 2010 | EZ Dupe (EZD1TDVDNEC) DVD±RW Burner
When i push copy on my DVD burner it says,Target Overflow,what do that means becouse it wont let me burn nothing its a[ TEAC 1 1 DVD/CD duplicator]
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
May 08, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will not copy Dvd, keep getting the message: "target drive not ready". Unit copies cd's alright.
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
Nov 06, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Wytron DVD 319 duplicator not copying to bottom drive
has it just started to do it. have you tried a different make of disc. they do change the dye now and again.
let me know
Jul 31, 2009 | Wytron Technology Computers & Internet
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Source drive not ready on 1 - 7 cd/dvd copier
is it old? when a ROM have trouble in its lens that won't enable it to read any disc, then it will always tell you that drive is not ready.
Jan 17, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
1,287 people viewed this question
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
