Question about Sewing Machines
Kenmore 385 timing answers
Hi! said you might be willing to share your directions on timing a Kenmore 385 sewing machine. My needle keeps coming down and snapping on the shuttle. I've had it into the repair shop several times (at $70 per visit) to fix this and it slips it's tune a few weeks later. It's already cost me more to "fix" the machine in the past 2 years since I bought it than it did to originally purchase it. I'm ready to heave the darned thing through the window!!! Help!!!
  • Anonymous Jul 02, 2008
    needel crashes in to the shuttle need timing adjustment but how
    Top Expert:
  • Sewing Machines Master
  • 48,226 Answers
The needle/ hook timing is achieved when the needle is in the lowest position and just starting to come up and the shuttle hook is at or close to the needle eye
there is a clamp on the vertical shaft the the needle is attached to so loosing of the clamp and moving the needle arm up or down to achieve that desired position is required
retension the clamp
if you machine is belt driven between the needle operation and the shuttle operation and it keeps altering timing it is possible that that belt needs replacing as the tooth sections of the belt may be worn off and jumping the teeth of the drive sprockets
it may be advisable to find another repair and get quotes first now that you have some idea of how it works
Posted on Jun 07, 2017
SOURCE: Kenmore Sewing Machine 385
check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
Posted on Mar 07, 2008
SOURCE: Kenmore 385. 11607 needle jams into shuttle or shuttle race
had same problem. took thread out...that worked. thanks drazil
Posted on Mar 08, 2008
SOURCE: our Kenmore 385 is not
There's some pretty old grease in these machines, and with oxidation, the grease tends to slow down the movement of parts.  My first suggestion would be to take the gray bottom off the machine, take the white cover over the free arm off the machine, and hit the linkage down here with lots of patient hair dryer time. I just "fixed" a 385 which would not go into reverse.  Reverse is driven by a spring, the button actually allows the spring to reposition a cam on the main shaft.  The old grease kept the spring from moving the cam.
Posted on Jan 04, 2009
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Posted on Feb 05, 2009
SOURCE: I have a Kenmore 385 (12116690) the thread keeps breaking
I have this same machine, it belonged to my husbands grandmother and was given to me after she passed. I let it sit for a few years before I got it out to use it, it was just too emotional. I had this same problem, and after cleaning, it worked fine. I followed the instructions in the manual for taking out the bobbin, bobbin case and metal parts that hold it in the machine. (there are pictures in the manual to help you take it out, take it apart, and put it back in... sounds hard but it's really not). I used a tooth brush to get all of the dust bunnies out (you could go over with a vacuum hose too, after the toothbrush cleaning). After I did this it worked fine. You may want to look in the manual about oiling the machine, if it's been years since it's been done, that might help to. Hope you get it working! I love this machine, it works well and is good quality. (they don't make sewing machines like they used to, the only one I'll buy is a Kenmore!)
Posted on Feb 27, 2009
After I broke a needle on my Kenmore sew machine 385 17622090 I installed a new needle but now my bobbin thread won't catch. Very frustrating
possible that when the needle broke ,the needle/hook timing was changed
take it to a sewing machine repair shop and have it checked and adjusted
Jul 24, 2017 | Kenmore Sewing Machines
Direction on how to thread kenmore sewing machine 385. Model number 1168291
Perhaps this will help:
Part 1 Basic Sewing Machine Tutorial Kenmore 385 Series
Part 2 Threading the Bobbin Tutorial on Kenmore 385 Series Sewing Machine
How to Thread Sewing Machine Kenmore Model No 385 16221 Series
Jul 25, 2016 | Kenmore Sewing Machines
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
I have a Kenmore model 385 sewing machine is this a slant machine?
The slant needle machines are Singers. Your machine will use low shank snap-on feet, if that answers your question
Feb 24, 2015 | Kenmore Sewing Machines
385 kenmore sewing machine
385 just means it's a Janome badged for Sears. The actual model number is the first 4 or 5 digits after the 385 portion.. like 385.1234567890
Machines that don't reverse are often dirty or the lubricants are gummed up (try running the machine in 15 minute bursts, full throttle, with the needle out; sometimes that helps.) Otherwise:
Mar 23, 2014 | Singer 3116 Simple
Bobbin thread will not pick up kenmore 385
Try a new needle and make sure that you have a long enough tail to hold when you lower your needle to pick up the thread
Sep 10, 2010 | Kenmore 11101 Mechanical Sewing Machine
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Feb 10, 2008 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
475 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
