Question about SanDisk Sansa e250 MP3 Player
Sansa e250 i need to restart my device
  • 91 Answers
Format Your entire MP3 player.
Thank You!!!!
Posted on Jun 23, 2008
I lost my software for my mp3
Hi
I see that you need the driver for your Sansa Sandisk e250, see links below for the download page.
http://kb.sandisk.com/
This will direct you to the Sandisk website just select your Sansa e250 from the list of devices from the website to get the driver softwarethat you need to make your Sansa e250 running.
I hope this helps.
Have a nice day,
mvincentc
Apr 27, 2011 | SanDisk Sansa e250 MP3 Player
Accidentally deleted everything on sansa e250 computer can't see device.
Hi there
I can understand issue. When you say the device is not detected. Then it could be an issue with the system files would have got deleted because of the format.
To fix this issue, i would recommend you to keep the device in MTP mode ( Menu->Settings->USB->MTP).
Connect the device to the computer.
It will give the message as Found New Hardware.
Go ahead and install the MTP drivers by following on screen instruction.
Then Unplug the device.
Restart the computer.
Connect the device.
Now we are offset and device will be detected.
IF still you have issue kindly revert..... Good luck
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
Computer reconizing mp3 player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Aug 27, 2008 | SanDisk Sansa e250 MP3 Player
Thought it was fixed
You're not screwed... Just lock your sansa and then hold REC button when starting up your sansa. Connect your sansa to the computer. then a device called 16MB-FORMAT should be in My Computer. Put this file : "http://www.MegaShare.com/392319"
onto that device. Now disconnect your sansa from your computer, and let the sansa do everything it needs to do. Then it will restart.
Make sure you unlock it. After this your sansa should work fine.
Apr 13, 2008 | SanDisk Sansa e250 MP3 Player
Sync Problems with my e250 Player
It could be a device certificate errror..what i would recommend you to get a firmware upgrade for your device...if that doesnt do it i would recommend you to contact sandisk...its a common problem with your device...hope that help your problem./..
Please rate accordingly...
Thank You
Jan 27, 2008 | SanDisk Sansa e250 MP3 Player
How to upload songs into Sansa E250
Th device may be too full. You need at least 6MB for each GB of music on the device to create the "database" or GUI. Delete a few song, restart the device. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 keeps shutting down
try and see if it is in MY COMPUTER if it is there download the newest firmware and update it if that doesn't work uninstall the mp3 player from your computer and then installit again.
May 20, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 keeps retarting
you should try formating it. when you plug it into your computer... go to my computer right click on your mp3 player name under " devices with removable storage" click format. make sure nothing is checked. and then press start. wait till its done, and it should work. good luck. i can use some to..
May 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
