Question about Toshiba 53H71 53 in. Rear Projection Television
Touch Focus Error
My problem is similar to the one I just read. When I run the TF setting in front of the TV when it gets to the RED lines it shows one of the lines like a SINE wave or curvy instead of straight across the screen. The picture on the TV also shows double-vision.
  • Anonymous Sep 07, 2008
    tf shows error in red and double picture no attempt to fix no owners manual
  • Toshiba Master
  • 8,617 Answers
You need to replace both of the STK392-110 ICs you can get replacements at the following link and they come with free instalation instructions with pictures. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 21, 2008
When I run the Touch Focus , it ends Touch Focus Error, and the Red Verticle line does not move , the Horizontal is bent .. now tv is fuzzy?
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | Toshiba 42H82 42" Rear Projection...
Hi, my tv shows a double image with red outline I pressed the Touch Focus and the red did not have a verticle was straight line, but the horizontal line was not straight, but came back with touch focus...
you have a convergence problem
it will require a couple new ics its best to replace as a pair stk392-110 although i recommed using the stk392-150 as a replacement and also there are some jumpers that should be resolderd on those boards to assure continued operation hope this helps you
Sep 11, 2009 | Toshiba 42H83 42" Rear Projection...
Red lines on Sony KP51HW40 Rear projection TV
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
57H81 Red Bleeds, Dull Color, Was Pink
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
Dec 08, 2008 | Toshiba 57H81 57" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 42 inch rear projection
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
Blue ghost
If you have the ability to work on solid state electronics and know how these circuits work, you will need to replace the convergence IC's in this TV set. If you do not, call in a pro to assist you in this repair. Good Luck
Jun 20, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
271 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
