Question about Kenmore 22422 Top Load Washer
Kenmore top load washer
Help!!! My washing machine will not drain. What can possibly be wrong with it? It's a 70 Series Heavy Duty Plus, Model # 82370120
  • chiki76 Sep 03, 2008
    My kenmore Heavy Duty 70 deries Extra Capacity Model 110. 92573200 doesn't drain, but i had some problem before hand. The lid switch wasn't working right so i put paper into the where the lid switch goes and worked ok for while. Now, i start my load and found water wasn't drain and timer doesn't work when the time click reach drain point. Is it because i had the lid switch problem? or just drain problem?
  • msa556762 Sep 06, 2008
    Washer doesn't drain .I looked for Blockages.When I lower drain hose All water Drains out of tub. Pump isn't making any funny sounds.
    Kenmore series 70 Model #82370120
    Genius:
  • 1,036 Answers
First check the oulet hose for any obvious blockages.
If you can hear the pump working fine, then check before the pump for any blockages (odd socks etc).
If the pump is making funny sounds or no sound at all, it needs clearing of any debris, and possibly replacing if faulty.
If the pump tests fine, but just doesn't work, ten the control board must be defective or a wire broken.
If this helps - please spare a moment to rate as Fixya! thanks.
Posted on Jun 20, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
135 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
