Question about Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
  • am13 Aug 31, 2008
    Water is collecting in my fridge compartment. Any solutions appreciated please?
  • Anonymous Mar 22, 2014
    freezer ok but fridge not cooling
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Posted on Aug 07, 2008
Hotpoint mistral plus
Sounds like a faulty thermostat, although fast freeze usually bypasses the stat so should then get to temperature. If the compressor and condenser are getting very hot and all is clean, check there isn't a condenser fan stuck underneath that is seized. If not, may have had a bit of a refrigerant leak and sucked a bit of air into the system. Call an engineer
May 19, 2012 | Washing Machines
Freezer is freezing cold... but refrigerator is not cooling good on side-by-side Hotpoint Model HSS251FMDWW. What number should it be set on??
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Hotpoint Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint rla50 fridge is freezing up
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 06, 2010 | Hotpoint RLA50 Refrigerator
The fridge is freezing my food
heatman101
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Refrigerators Logo
918 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
