Question about Hitachi Computers & Internet
Trying to install a sata ata 133 drive and need to find the drivers. Cannot see them on their website any clue where I can get theses from?
  • Chris Hall May 11, 2010
    who makes the drive and what model is it?
  • 407 Answers
Go to drierzone.com & download its driver ..........
Posted on Jun 21, 2008
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
Trying to run ms windows xp home install disk. I have the driver for the host controller, but when I try to repair or install new...it said it can not find disk drives. when booting up I can see the two...
Go through the prompts,then have your computers compatability wizard check first.Then look for the drivers properties.Then see if,after it installs the computer still doesn't read the disc then write or call microsoft.Or ask them online about this.
Feb 15, 2010 | Sabrent Serial ATA (SATA) 1 External + 2...
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Need to install my new dvd writer on my dell dimension 9200 pc. The plugs are different. now what?
If the plugs are different most likely you bought a SATA drive. If your MB doesnt support SATA then there really isnt any use for that drive, i would return it and purchase an IDE drive, chances are thats what you have. Good Luck!!!
Aug 04, 2008 | Computers & Internet
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Computers & Internet Logo
13 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
