Question about Sony Cyber-shot DSC-S700 Digital Camera
Help!! USB Camera card stuck in Toshiba
I put the usb card to my mom's camera into my Toshiba computer's usb card lot and it is stuck a good inch in their anyway to get it out? I have tried using needles to pull it out..
  • 10,594 Answers
Use tweezer to pull it out.
Posted on Jun 21, 2008
Can't import pictures from camera to PC
What have you tried and what happens? Did you connect to a usb port on your computer and switch on the camera? What did you see on the camera? what did you see on the computer? If you can't get it to work with a known good usb cable and setting the options, just get a card reader take the card out of the camera put it in the reader or directly into your computer if it has a card slot, and transfer from the card directly. Let us know where or if you get stuck.
Jul 20, 2014 | Pentax Cameras
Why does the usb connection not reconized?
Have you tried NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
As to why your USB connection isn't working, there are a lot of possibilities. You may not have the right driver. If you're going through a USB hub, you might try bypassing it and connecting directly. There could be something wrong with the cable. There could be something wrong with the computer's USB port. There could be something wrong with the camera's USB port.
The main reason camera manufacturers include a USB port on their cameras is not so you can use it to transfer photos. They put it there because other manufacturers put one on, and so the marketing department insists they do so as well.
May 09, 2012 | Canon PowerShot A720 IS Digital Camera
How do i put a picture in camera to the computer when its no memory card in it?
You can go to almost any electronic store and find a matching USB cable - (secret a lot of computer cords are interchangable) hook it to the computer and download it...
Nov 03, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
My mom gave me her sony cybershot dsc-s650 and said to transfer the pics to my PC to just use a regular camera cord. On my old camera I just put the cord in, turn on the camera and it downloads. I do that...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 26, 2010 | Sony Cyber-shot DSC-S650 Digital Camera
I am looking for an adaptor or usb in which to charge the camera and put pic on my computer
Get the Digital Technology 50-in-1 HI-SPEED Card Reader/Writer or at least that is what I got from my mom while in Georgia. It was like from Wal Mart or smething. I see them all the time. USB.
Dec 30, 2009 | Polaroid i1035 Digital Camera
Can not get the cd to install on my computer for a Canon Digital camera
After ripping my hair out over this one, it turns out the driver software is incompatable with a lot of computers (mine is a Toshiba), but luckily I got a SD Card Reader with my camera, so I could just use the SD card instead of hooking up the whole camera with a cord. It has a simple USB connection you insert the SD (memory) card into the end of.
I found once I got used to it, it's a lot easier.
Dec 30, 2009 | Canon PowerShot A480 Digital Camera
Reply
Hi there again,
I am assuming you are using XP OS.....
I have a couple of questions for you.
Try this.............
With computer on and camera NOT connected,
Please look at my computer,
1.What happens when you connect camera to usb lead then connect the lead to the computers usb port?
2,Would it upset you if we use another way of moving your photo and video files from camera to computer?
3.Does Memory card work in another device or computer?
Solution 1 =================================
If usb did not recongise the camera on the usb port then it will be a software and hardware reinstall ,
Remove usb lead from computer
Go to Add/Remove from you control panel.
Remove the cameras software.reboot.
restart install software first and reboot,
do not connect camera yet,WAIT.
once restarted add camera via usb
should be good to go.....
If it does continue to give you issues then consult the manufactuerer.
Solution 2 =================================
if the usb is connected to the camera via usb lead to usb port on the computer and you can see the cameras' drive info then its more than likely you will be able to open and use this file ,if so you should be able the move these files to your computer too.
Solution 3 =====================================
Explains itself really-Replace it if you need to.
Hope this sorts out your problem.
I beleive your card reader may be poked,
Uninstall and reinstall try again, replace if presists.
these solutions I have put forward have been proven to work in many situations so good luck and let us know the results thanks
Jul 16, 2008 | Computers & Internet
Place for a memory card from digital camera to
It does not appear that this laptop has a media slot for you to put your memory card into. So you can use the USB cable that came with the camera - but I find that it is always very slow, and uses up the camera's battery pretty quick.
So you may be better off getting a USB media reader. you'd remove the memory card from the camera, put it into the slot in the reader, and plug the reader into a USB port. In My Computer you'd see a new drive pop up, and you could click on the DCIM folder, and then the 100XXXXX (where XXXXX is the name brand of the camera, or some portion of it) folder, and you can then cut and paste your pictures to the computer. If you Cut instead of Copy, it deletes the pictures from the media, so that when you put it back in the camera, it is blank and ready to take more pics.
Feb 08, 2008 | Toshiba Satellite A15-S157 Notebook
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
