Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
When I turn the set on, the power light comes on but the screen remains dead
A few weeks ago i was watching tv... the set suddenly went dark but the red 'power' light remained on. I unplugged it and attempted to try again the next day but no go... same problem. I called a repair company to take a look at it; they poked around for a few minutes then came out and said it would cost me over $400 to fix. He gave me a lot of technical jargon to explain the cost but I sent him away... perhaps he is right, but I wanted to check around first. A friend says that it could just be a blown bulb or something. The set is only about 3 or 4 years old, is it possible that it has failed so soon? Thanks, folks! --Jeremiah--
  • Philips Master
  • 3,459 Answers
I had the a similar issue. My TV broke - no sound and no video but the power light was still on.
I gave up and called in a repair tech.
He fixed my TV in less than 30 minutes by replacing a bad IC chip. He informed me that this is a very common problem with the older Magnavox TV sets and that its typicaly the same chip that fails.
I spent over 300.00 for the repair. The parts cost less than 20.00.
To help others in the same boat I put together a how to guide and parts kit on www.magnavoxhelp.com .  I'm not sure if it will work for you but it may be worth a shot.
Posted on Jul 05, 2008
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Loud pop from projection TV, then no screen
Ur power board it dead.Replaced capacitors that puff up or pop open.Or replaced the whole board.
Dec 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
TV screen went dark, but sound still there.
your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
Nov 28, 2008 | JVC LT-40X776 40 in. LCD HDTV
Flickering
I will buy a new TV before I'll fall for this scam.
May 20, 2008 | Akai PT5492S 54" Rear Projection...
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Samsung HDTV Oval rainbow of colors covering entire screen
I HAVE PANASONIC MODEL TH50PE700U WATCHING IT AND THE COLOR WENT YO B/W
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
