Question about RCA 25403RE3 Corded Phone
Phone Registration Our phone needed new batteries, I put them in and the phone that has a cord is working fine but our cordless won't work without some kind of registering with the corded phone?? We can't remember how to do it, can anyone help?
The manual says to hit select/save button and it will register phone to base. Mine however will not..am waiting on manufacturer to get back to me. Hope this helps.
Posted on Aug 14, 2008
What is registration mean on phone
Each cordless handset must be "registered" to work with a particular base station. This way, even if you and your next-door neighbor have the same make and model phone, you won't interfere with each other's conversations.
Jul 19, 2012 | Lands Phones
I'm so embarrassed...my cordless phone died and a friend loaned me an old corded one but I can't figure out how to get power to it. It's a Panasonic corded phone, Model No. KX-77020 whichi is...
Give it back to your friend. It won't work without a Key Service Unit.
Take yourself to any box store like Target with a $20 bill and get a Uniden basic cordless phone, or any drug store and buy a $10 corded phone.
Carl
Sep 20, 2011 | Panasonic KX-T7730 Corded Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
Uniden wall-mounted cordless phone unusable since DSL installed
This happened because there are too many phones sharing the same line with no power amplifiers.
Your phone line is self powered by a small current generated by the phone company (that's why old, wired phones don't need a separate power connection to ring or make calls, it's enough to just plug them in). Each phone you connect to the same line acts as a resistor and drains some of this current. Eventually not enough power is left to carry the signal.
The phone company technician can fix this by installing power amplifiers.
In any case, I would test this theory by unhooking all other phones and checking the cordless ones on their own.
If they work fine, call back the phone company and ask for a "real" repair person..
Jul 13, 2010 | Uniden Cordless Phone
Just purchased GE model 28101 hoped to add to existing phones. Battery was dead and will not charge. Put battery in from existing phone and now lights up. Calls for registration at base unit. I have...
I have determined that the phone purchased is not compatible with my current phone system. My mistake for not understanding the fine print on the box!!!!!!
Sep 08, 2009 | Uniden Cordless Phone
Just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
Mar 23, 2009 | Uniden 5.8GHz Dual Cordless Phone
I bought a Uniden cordless phone, put the batteries in (it has 4 remote bases) and charged it for 20 hours as instructed. I tried calling it on my cell phone but I'm not getting s response. The display...
Double check that the telephone cord is firmly plugged into the back of the cordless phone base, the wall outlet, the outlet where the telephone modem is and at the L1/L2 jack on the back of the telephone modem. Your phone is not getting the dial tone line voltage from the telephone modem to the cordless base. There might be a short in the wiring. (It is unclear as to whether you are setting an old phone into this new base or swapping out and using another base with the old phone. Irregardless, the problem would seem to be not in the phone but ratther narrowed to the cord between phone modem and phone base. That is a very good reason to check how firmly the cord is plugged in.
Aug 27, 2017 | Lands Phones
GE handset registration?
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
Dual Maxus 5.8GHz Handset Cordless Phone
After the batteries have been fully chaged, thephones will still not work until the they have been registered to the base unit. Just put each phone in the charging cradle in the base unit for about 10 seconds. The indicator light will blink during the registration. If you are lucky, this may solve the problem.
Nov 23, 2007 | Dual Maxus 5.8GHz Handset Cordless Phone
RCA 25403RE3 Corded Phone Logo
116 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
