Question about Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive
Internet viewing of my home security system
I have a new SSC17WEB system and I could not open http://sff0000.websamsung.net as requested by the manual to register in Samsung DDNS server IPaddress.
I want to view the 4 cameras over the internet.
Thank you
Frank
  • 3 more comments
  • RAIDERRICK Jul 28, 2008
    I'VE TRIED THE SAME THING & I'VE TRIED CONNECTING DIRECTLY TO MY DESK TOP & I DON'T GET ANYTHING,NO SIGNAL.
  • vo03 Aug 16, 2008
    I have the same problem.  My SCC17Web already connected to  DSL router, but when I go to URL to type Mac addresshttp://sxxxxxx.websamsung.net as in the manual, the Internet Explorer can not find the address.  Please help me to find out.  Thanks so much
  • proweller Feb 11, 2010
    I can't get it to work with anything newer than Explorer version 6 ... works great on 6 so-so on 7 and not at all on 8 ... go figure..
  • albert001 Jul 18, 2012
    i need help, this thing is driving me crazy, this thing only work only in public ip addresses please help
  • Anonymous Mar 30, 2014
    NETWORK .. DDNS FAIL
Frank, if you have an external IP, you can open a port on your router and viewit that way. Works great for me. ANyone know how to view the system with Vista??
CAD...
Posted on Jul 13, 2008
  • Quint Sorbelli Dec 05, 2012
    how do you open a port on a router?
Actually you need to configure your router, to allow incomming requests into the designated ip address. The ports to open are usually 6100 and 80, good luck.
Posted on Sep 15, 2010
How to install activex manually?
To view your DVR remotely through the internet web interface, you must properly set your ActiveX controls in Internet Explorer.
First - Make sure you are not connected to or ar tying to connect to the DVR! Close the Browser and open a new one if you have to.
In your Internet Explorer browser, select the Tools drop-down menu above, and choose Internet Options. Choose the Security tab in the corresponding pop-up window that comes up.
[img src="http://asapcctv.com/software/standalone/img/SecurityTab.jpg">
Now click on the Custom Level button at the bottom of the Internet Options window. Scroll down until you see ActiveX controls and Settings, and apply the following changes:[img src="http://asapcctv.com/software/standalone/img/CustomLevel.jpg">
Follow the image below for the correct ActiveX Settings. (The settings as shown does not make your system more vulnerable, but maximizes your browser's security, while putting the choice of operation in your hands on a case-per-case basis.)
NOTE: These settings reflect versions 6-9 of Internet Explorer. Depending upon your version of IE, your controls may not follow exactly the same order or have all the options shown below -- Just make sure those you do have match what is shown.
[img src="http://asapcctv.com/software/standalone/img/ActiveX.jpg">
OK, and then return to your browser by clicking OK again.
Close your Browser and open a new one. You should now be able to install any ActiveX controls needed to run any DVR remote software.
Be sure to accept any requests for software installation after typing your DVR address into the browser address bar. There may be several controls to install.
Mar 25, 2014 | Dome 4 CCD CCTV Camera Surveillance...
Tip
Samsung SSC17WEB Manual Download
Download Samsung SSC17WEB Installation Manual
Have you lost the Installation Instructions for your Samsung SSC17WEB Quad Observation System?
Click here to download a digital, searchable, pdf version of your users manual / installation guide.
I hope that helps.
on Apr 21, 2010 | Home Security
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Mar 11, 2014 | Acer TravelMate 2480-2779 Notebook
I set up my Surveillance system and I can view the cameras on my iphone at home but when I leave I can not?
Your phone is most likely connecting via Wi-Fi when you are home, but after you're out of range of Wi-Fi, your Surveillance System must be set up to give you access through the internet. The camera instructions should tell you how to set it up and the manufacturer probably has an app that you need to install on your iphone to access your camera system from the internet.
Sometimes setting up internet access is no easy task. You must open a web port on your router in order to send and receive the signal from your security system and communicate with the internet. Determine which port the security system is set to communicate with and open that port on your router.
There are so many different configurations for security systems and routers that it would be impossible to specifically lead you through each step. But I hope this general description will be helpful in getting you started.
Sep 17, 2013 | SVAT Home Security
I need to start with my home page www.tesco.net
Open internet explorer. Goto www.tesco.net then select tools then internet options on homepage click "use current" then click "apply". This will set www.tesco.net as your homepage.
Sep 11, 2009 | Compaq Presario C700T Notebook
Removal of virus from pendrive
hallow ,,u got virus in you pendrive ,i can give you a website throught which you can download norton antivirus 2009 { norton the best antiviris virus company } 1 ..download azerus from this website http://www.toggle.com/lv/group/view/kl25534/Azureus.htm 2....download the norton antivirus torrent with this website http://www.torrentreactor.net/torrents/2650987/Norton-Antivirus-Norton-Internet-Security-2009-%2B-Trial-Reset-Coly-%28Re-Uploaded%29-%28118S%2F9L%29 and open the download torrent with azerus
Jan 05, 2009 | Microsoft Windows XP Home Edition
Gmail and google won't open
Reset IE7
1) Click Start button-> Control Panel.
2) Change to Classic View on the left pane and double-click the Internet Options icon.
3) On the Security tab, click Default level button for each icon in the Select a zone to view or change security settings.
4) Click to Programs tab, and then click the Make default button if it is not grayed out.
5) Click to Advanced tab, click Restore advanced settings button in the Settings area.
6) Click the Reset button in the Reset Internet Explorer settings area and Click OK.
7) Click Apply, and then click OK.
Dec 10, 2008 | Microsoft Windows XP Home Edition
Windows Vista Basic or premimum ?
You can find all the details & info here :
http://www.microsoft.com/windows/products/windowsvista/editions/default.mspx
And
http://www.microsoft.com/windows/products/windowsvista/editions/starter/default.mspx
Home Premium
Windows Vista Home Premium is the preferred edition for home desktop and mobile PCs. It provides a breakthrough design that brings your world into sharper focus while delivering the productivity, entertainment, and security you need from your PC at home or on the go.
Home Basic
Windows Vista Home Basic is ideal for homes with basic computing needs like e-mail, browsing the Internet, and viewing photos. Easy to set up and maintain, it enables you to quickly find what you're looking for on your PC and the Internet, while providing a more secure environment to help protect you from an unpredictable world.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot view security system remotely on internet
Check IP address make sure it is correct. Also firewalls will prevent you from linking to dvr.
Nov 02, 2007 | Lorex 4 Channel Business & Home Security...
Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive Logo
2,812 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
