Every time I turn on my computer there is a 1/10 chance the there wil be sound, so i keep restarting and it takes ages before they work. Why is it doing this? When they do work there perfectly fine.
Comments:
Jul 20, 2008
- Thanks but no thanks. I had fixed the problem days after posting. The problem was that one of the sound cables were 'loose?' I thumbled around and and the wire needed fixing up. Very easy to fix but thanks any way.
What type computer? Vista or XP? I take it you have X-530 speakers?
Go to control panel,and check device manager to see if you have any
problems. If not, click on Hardware and Sound, then on Sound, and you will see the "Playback" tab. Highlight "speakers" by clicking on it, then click on "configure" to see
how your laptop speakers are configured. If you have a laptop, your internal laptop speakers should be turned off. Configure
them for your external speakers
and test the sound there. If you need to use your laptop speakers (say
you take your laptop somewhere without your external speakers) you will
need to reconfigure your sound to the laptop speakers. Let me know if you have further problems--you may need to update your sound driver.
Have you done maintenance on your computer, such as getting rid of unnecessary files and defragmenting the hard drive? If not, go to "applications" in your program files to do so.
I use i tunes for all my music, i'm not getting true 5.1 sound, only working, set on 6 speaker...
(More)
I use i tunes for all my music, i'm not getting true 5.1 sound, only working, set on 6 speaker setting now, 5.1 setting nothing. I've run a test for 5.1 and it's fine, separate sound in all speakers. Is there a way to get true 5.1?
the volume button on my loghitech x-530 speaker system became loose and had no sound i took apart...
(More)
the volume button on my loghitech x-530 speaker system became loose and had no sound i took apart the speaker and found the voulme conncetor had bacame loose and i have tried to reconncet it but i have had no luck
