Question about Brother MFC-3240C All-In-One InkJet Printer
Brother mfc 240c does not recognise new cartridges have been installed and gives message that no black cartridge and colors are near empty, new genuine cartridges have been installed.
  • Anonymous Jan 27, 2009
    Same prob. Replace Ink, Near empty mgent, and Ink empty cynan appears on the screen.
    thank you
I have had the same problem on the Brother MFC-3240C and here is my solution.
Turn off printer
Remove all ink cartridges
Turn printer on and wait 15 second until the power on checks are completed
While the printer is on install the ink cartridges
The display will ask if new cartridges were added, answer with yes for all cartridges.
The previous false cartridge indicators are now corrected
Hope this helps!
Posted on Jan 03, 2009
I switched my printer off ( by pressing the button with the words power save beside it for a while, like say 5 seconds?) and on again. it now says ink near empty, but i can print.
Posted on Nov 16, 2008
This is what i did as a last resort after messing with this stupid printer all day and changing cartridges and getting a no cartridge message.
i took all of the ink cartridges out and took a pair of pliers and pulled out what i think must be the sensors. they are black plastic pieces toward the top part of the ink area. then i put the cartridges back in and i have been printing ever since. this was my last resort before i was prepared to throw in the towel so that was why i went at it with the pliers!
Posted on Nov 08, 2008
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
New black ink cartridge - Machines says No Cartridge
just clean the place where your ink is installed clean it with cotton and alcohol..try to reinstall your ink slowly and make sure it contacts properly..hope this works...ITTech7574
Aug 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-3240C All-In-One InkJet Printer Logo
320 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
