Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Not cleaning the dishes
My ge dishwasher is 3 years old, we do not have hard water...the inside is clean..and no visible clogs..and yet my dishes still come out dirtier than when they went in??
  • gagie24 Jul 07, 2008
    My dishwasher is brand new and I am extremely disappointed with it!!!!
    I need to run the dishwasher at least 3 times before they are remotely clean. Even then, I need to hand wash them. My dishes NEVER feel clean.
  • aimzer Sep 21, 2008
    My detergent isnt getting dissolved either...
Make sure you don't have tall dishes in front of the detergent dispenser that would prevent it from opening. Put short dishes like salad plates there.
Posted on Apr 12, 2013
  • 54 Answers
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Posted on Jul 04, 2008
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
The dishwasher is 4 years old. It is not cleaning the dishes. Even when they are rinsed. Water temp is high enough.
Hi, try removing the spray arms and see if they are clogged - and of course unclog them. Also might be inlet valve. If you are at all technical, find it, remove it, see if it is clogged - if you have hard water - which most people do - it will clog up and should be replaced. You can use vinegar and special cleaning agents but most likely the problem is as aforementioned.
Jun 24, 2011 | General Electric GE Profile Dishwasher 24...
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Dishes are not clean at end of cycle g e g l d 4300l00ww 3 years old
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Aug 31, 2010 | GE Dishwashers
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
Hi
Hope this helps...
Daniel
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
Dish washer 3 1/2 yrs old making a growling/vibrating sound.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes not getting clean
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
178 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
