Printer works fine for months and then all of a sudden today,
I hit an icon to print something and this box with info in it comes
up and says:
There was an error when printing started. To check the printer setup,
double click the printers icon in windows control panel.
I finally found the windows control panel and clicked on the icon came up and had nothing to do with the problem. I checked the
connectionh and power cords...and checked for jammed paper. I called friend that knows about this stuff and he said to call you.
Lexmark E120
TLI: 23S00300
Config ID: 400D89
Type: 4506-110
S/N: 9948MBP
Region 1
Did you make sure they were not expired when installed in the printer?
Still what i can suggest you to do is. Remove the cartridges clean the contact on the cartridges and also in the printer. And turn off the printer. Now turn on the printer and wait for the printer to show error for cartridges and now you can install them back and try,
This might not be a solution, but rather something to get your job done if nothing else (if it works):
Try using the "manual feed" tray instead of the paper tray. Depending on where the jam is occurring in the machine, it could bypass that spot and print fine.
Click on Start button Click on Run Type SERVICES.MSC and click ok look
for Print Spooler in the list highlight Print Spooler, Click on
STOP button then click on START close the window and check if the
print queue is gone.
Alternate method,
Click STart Click
RUN Type Cmd ( or COMMAND ) and hit enter In the black window
type NET STOP SPOOLER ( hit enter button ) Type NET START
Repeat the Stop and START Command
4-5 times End the Command with NET START SPOOLER
Open
Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Hi, my name is Sam, and I think I know how to help you. First please press, start and go to run then type "control printers" in the text box. that should bring up you printer icons and click on you printer icon. A box should come up titled something like HP PhotoSmart PSC 2400 Series, go to the Printer menu and click on Printing Preferences..., go to the Effects tab and set "% of normal size" to 100 % of normal size!
Sorry the printer hardware is not supportting MAC leopard as printer is old and lexmark dont have driver for mac leopard:that why the printer is not working...
