Confirm you timing belt marking at the engine before you start the work. then dismantle all the belt one by one until you reach the timing cover. mark the timing mark again. then start dismantle the timing belt set. after all the belt are out, open the water pump and start to put back the new part by using reverse order from the opening list. make sure the timing marking are the same as you check at the first time. before you start the engine, make sure you turn the engine 2 or 3 round and make sure no part are hitting. good luck.
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
How
How
How to Remove Water
Pump?
----------Below is the master help link provided to go through belt routing diagram:---Timing belt,drive belt,serpentine belt,accessory belt,fan belt,engine belt routing diagrams for all types of car models?
Click the link below :----http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help.Thanks.
provided below.
provided to go through belt routing diagram:---Timing belt, drive belt, serpentine
belt, accessory belt, fan belt, engine belt routing diagrams for all types of
car models?
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
Click
this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
For water pump replacement i suggest you to check the help link provided below.
How to route Water Pump Belt ?
