Question about Aiwa CDC-X517M CD Player
Aiwa CDC-X517M Car CD Receiver . . .
I have a aiwa CDC-X517M Car CD Receiver but I lost all the wires to hook it up in my car. I have no idea what they are called so I can't look online to see where I can buy more. I see on the back where it has the four spots to hook up the wires for REAR and FRONT and then it has a number 15 fuse and something else that plugs in above it, then thre's a circular thing with about 13 holes and one little square hole.
Let me know what you think.
Thank you.
  • Linda1958 Jun 22, 2008
    This is exactly what I needed to know. Thank you very much for your time and effort to help us. We really appreciate it.
    Linda1958
  • Anonymous Mar 30, 2009
    I have a aiwa cdc-x517m and have lost the wiring connection and am inquiring to see if someone can help me.
    President:
  • 624 Answers
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Dave
Posted on Jun 20, 2008
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Just had aiwa cdc x204 stolen from car but they left wiring harness intack. Cannot find this stereo anywhere. Is there another Aiwa or make that uses same wiring harness?
Most modern car stereos all use a standard plug (the name escapes me at present) so virtually any stereo should just plug in...
If your not sure, pop in to a motor parts place such as halfords and ask them to take a quick look at the wiring in your car... they will tell you weather it is standard or not...
Aug 27, 2010 | Aiwa CDC-X204 CD Player
I just go an AIWA CDC-Mp3yu car cd player out of my jeep for my car but the plugs none match i found an adapter for the one with all the wires but cant find adapter for antenna an i need to know what the...
It's most likely a connection for a cd changer unit. you may be able to get an aftermarket cable to run an ipod... cool stuff.
For an antenna adapter... the local stereo stores carry those as well as the wiring harness adapters...
Jun 10, 2009 | Aiwa CDC-MP3 CD Player
Unresponsive face plate/ buttons
check wiring to make sure all wires r properly connected, sounds like a power problem . if it is an expensive radio and it is broken then its probably worth fixing.if its a cheepie than chunk it and get a new one
Apr 28, 2009 | Aiwa CDC-X204 CD Player
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Wire harnest order
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
Nov 04, 2007 | Aiwa CDC-MP32 CD Player
AIWA CDC-x227 CDPlayer
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Dec 03, 2006 | Aiwa CDC-X227 CD Player
Aiwa CDC-X517M CD Player Logo
182 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
