Question about Sharp Televison & Video
Sharp VCR VC-A542 has a key symbol in the led area and ejects tapes automatically inserted.
  • 883 Answers
SOURCE: Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
  • 191 Answers
SOURCE: Have a Sharp VCR player/recorder
The sensor for the tape deck has gone bad need to replace it.
Posted on Aug 20, 2008
SOURCE: automatic eject
hi it guys,
i would like to share this issue of tape eject on my server from yours,so pls send me the solution of this issue and let me know of the same issue.
Posted on Oct 17, 2008
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
My sharp VCR wont accept tapes, they pop out when I insert them, help?
This often caused by a faulty carriage assembly. Another cause is a mode switch failure. The mode switch tells the electronics what position the VCR mechanism is in. When it goes faulty it will cause the tape to eject sometimes. However any kind of mechanism damage can cause the mode switch to go into a wrong position.
Aug 05, 2014 | Sharp Televison & Video
Sharp VC-H973U suddenly unable to play/record tapes
With these things it's best to see what is going on to see if it can be fixed. So what I suggest you do is take the top cover off and using an old tape which you don't mind getting mangled insert it and watch where it gets tangled up. Without looking into it you can't determine what's faulty.
Jan 21, 2013 | Sharp VC-H973U VHS VCR
VCR won't record.
When you press record, does the tape eject? if it does, make sure the safety tab is intact. if not, put a piece of scotch tape over the hole. Do you hit the record button on the vcr or a universal remote? On a remote, you may have to hit recort 2 times.
Jun 19, 2010 | Sharp VC-A582U VCR
The VCR doesn't eject the tape
need codes for vc-aa350 is locked
Sep 01, 2009 | Sharp VC-A560U VHS VCR
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
Loads then unloads the tape
could be a sensor problem. look at bottom side of videotape. in the center towards the top is a round hole, above a screw. then insode the vcr (take top cover off) theres a prism or led sticking up that goes into that hole in the tape, when the tape is loaded. try wrapping masking or electrical tape around it (only a temporary fix)
Feb 20, 2009 | Sharp VC-A410U VCR
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
