Question about Broksonic CTGV-5463TCT TV
Can't program the DVR remote to cut my broksonic tv on or off.
I just recently switched to the time warner dvr cable box and I can't get the remote programmed to control the my broksonic tv. I tried all the codes listed in the manual, the rep at the cable company said that maybe you all had a universal code that I could use.
mslewlew in NC
  • cbthai Jul 31, 2008
    can't program my time warner remote to my broksonic tv
What is the code for broksonic universal remote code
Posted on Sep 15, 2008
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Yamaha DVR C-300 home theater no remote. Have time warner cable remote UR5U-8780L Can I program it
I recently purchased a "Harmony" multi remote controller from Dick Smith Electronics. You have to go into the Internet and download some programming material for it, but it has 100,s of different make and models that you can access to reprogram the remote. it works on Tv,s DVD,s Videos etc. I lost my remote for an old Conia TV and it now works perfectly with the Harmony remote.
Nov 27, 2015 | Yamaha Audio Players & Recorders
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Need code to program emerson jumbo universal touch screen remote to control Time warner cable DVR?
if you have the user manual of the remote control try as VCR not as TV.
Feb 16, 2010 | Televison & Video
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
I rent a DVR from time warner cable. My remote quit working & I want to tape some programs today. How do I do that manually?
First off, time warner makes decent remotes, but they are cheaply made. If you have a menu and selection button on your box, you can use those to navigate to the menu you need, and set it up. It will probably take longer without the shortcuts, but there are worse things.
Oct 22, 2009 | Cyberhome DVR 1600 DVD Recorder
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Oct 07, 2008 | Televison & Video
Broksonic CTGV-5463TCT TV Logo
452 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
