Cartridge is stuck . Does not eject. - Televison & Video
  • hisam Jun 20, 2008
    Its Mitsubishi model # HS-U550
  • Ken Jones
    Ken Jones May 11, 2010
    Thank you for your question. Before I give you a specific answer, can you please give me the make and model # for your device?
    Thanks
    Sergeant:
  • 260 Answers
Thank you for your information. This does not appear to be a common problem for this model but it is a common problem for VCRs in general. The solution requires you to remove the cover of the unit. Before you do this I recommend that you use our premium chat service so someone can walk you through the repair. Or use our online list of technicians to find a professional near you.
Good luck. :)
Posted on Jun 20, 2008
My 2000 SL500 6 CD cartridge will not eject The player works fine but I want to put in 6 new CDs and cannot get the cartridge ejected
There probably is a CD hung up between the magazine and the player mechanism. There is no easy fix. You will have to remove and disassemble the unit to get access inside. Once everything is back in place, apply power and try to eject the magazine. Otherwise, you may get the unit reinstalled only to find the magazine is still stuck.
Mar 27, 2017 | Mercedes-Benz S-Class Cars & Trucks
Cartride won't eject
The magazine may not be able to eject because a CD is stuck and not completely seated inside.
Mar 26, 2014 | JVC Xc-m75 Kenwood 6 Compact Disc Magazine...
My in-car cdc will not eject the cartridge?.
Press the eject button several times non stop.Like 10 to 15 times non stop and see,if the cartridge is getting ejected out.If its still stuck,then disconnect the car battery negative terminal for 15 minutes then reconnect the negative terminal and heck.If still the cartridge is stuck,then its problem with internal mechanism.You will have to disassemble the unit and manually eject the cartridge out and lubricate internal mechanism.-------------- Unplug the changer and use a flat metal ruler.And slide it alongside the cartridge. try sliding on both sides. You'll eventually trigger the manual switch and it'll pop out.Bif that is also not helping then:--- solution is to disassemble the CD changer and lubricating the mechanisms inside. This is the most common problem with CD changers. Take the unit out of car and try to release disc manually.Take the screws out on both sides of player then remove case . You will be able to manually push the big gear so that the disc goes back into the cartridge. And then it slides out. After that you lube all moving parts with a teflon grease and some parts with silicon spray. This will help.Thanks.Helpmech.
Feb 17, 2011 | Car Audio & Video
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Sep 29, 2009 | Car Audio & Video
Paper gets stuck, eject indicator keeps blinking with out any effect on pressing it
its the problem in the main board of the printer that has shorted out the new colour and black cartridge in your printer which you installed.or may be one out of them.it happens some time.so you will have replace the cartridges 1 by 1 with new cartridge and check out.if still the problem then replace the board.that costs $12 plus shipping. mostly the cartridges have shorted out and replacing the cartridges will solve.
May 08, 2009 | HP DeskJet 610c InkJet Printer
Cd stuck in the cartridge of my car.
i Have a 2000 olds bravada and i have had the same problem. Get a pencil or scribe something small a key might even work. Push eject then use the tool of your choice to push the cd down while it is trying to eject. worked for me.
Mar 22, 2009 | 2001 Oldsmobile Bravada
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Televison & Video Logo
Top Televison & Video Experts
