Question about Cyberhome CH-DVR1530 DVD Recorder
I don't get any sound when I play a DVD on my CH-DVD 1530 DVD recorder.
I put in the DVD, it plays (I see the picture) But I have no sound. What am I doing wrong???
  • Dave DeGain
    Dave DeGain May 11, 2010
    Do you get sound from it with another source like the TV tuner or anything that you connect to the inputs?
    Make sure that you have the audio output connected to your TV or your stereo receiver. It has RCA jacks for the audio output and if that is not connected to the input of your TV's audio input jack on the same input as the video input or connected to the audio input jacks of the receiver. Whatever you use for sound make sure the output jacks are connected to it.
    If you are using the digital output, it has 2, make sure that the source for the device it is plugged into is set for digital input and not analog.
    Without more information about what the DVD recorder is connected to and what connections you are using, this is about all I can offer right now.
    If this information was helpful I would really appreciate a good rating, and if it still did not help please post more information and I may be able to help you further.
    Thanks and good luck,
    Dave
    President:
  • 624 Answers
Do you still need help with this problem? If not, just ignore this post. If so, please provide more information.
Posted on Oct 16, 2008
    Sergeant:
  • 260 Answers
The solution to this problem depends on the current setup of your device. First, try a different DVD. If that DVD works (makes sound) then the problem is not the DVD player.
If the DVD does the same thing the the problem is the player or speakers. First, make sure the output from your DVD player has cables coming from the red and white outputs and that they are connected to your television or audio device. Second, if you are using a single cable like a coax cable, then try replacing the cable. If that does not work, then check your television or audio devise to make sure that is has sound when changed to other channels. If you still need help please try our premium service or contact a local technician from our online technician list.
Good luck :)
Posted on Jun 20, 2008
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Have a video cassette recorder & dvd/cd player. Need instrucdtions on hooking it up correctly
power off all items... do you have cable/satellite (this cable wire needs to be connected from box to the in on VCR) from the out on VCR connect back to TV...okay DVD you should have 3 cable wires (red/white and yellow) this is to be plugged into AV1 (on the back or side of TV) follow the colors... red to red and so on...note you should tune your Flat panel CH 3 along with the VCR (set it CH 3)... okay turn on all, get a tape, pop it in VCR press play... do we have a picture and sound? okay press stop.. get a DVD disk place it into DVD player press play.. using your TV remote we need to change the source from component/cable to AV1 in order to view a DVD. and change it back once finish so you can view regular TV. okay do we have picture and sound?
have fun enjoy your movie
Aug 09, 2011 | Televison & Video
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
Will not play what i have recorded
Maybe it the problem that u dont close the session on the CD/DVD. Finalize the CD of DVD and u can play it on every DVD/CD player
Jan 08, 2009 | Cyberhome CH-DVR1500 DVD Recorder
I have a Panasonic DMR-ES30VEB. Video and DVD recorder. It won't play any shop bought Video's. No picture, No sound. Video's I have made myself I can watch. Picture and sound fine. When dubbing shop...
Are you playing it through the vhs mode. It will not play through the dvd mode via 'TJ' or dubbing as the dvd record function is macrovision protected
regards
snapper
Nov 26, 2008 | Televison & Video
No picture when playing dvd
Does moving the button or mode restore the picture?
Jun 14, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Cyberhome CH-DVR1530 DVD Recorder Logo
52 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
